Will 10.5" wide Tires rub w/ stock Grizzly Rims and 8.8 Axle? - JeepForum.com
post #1 of 3 Old 06-24-2011, 01:51 PM Thread Starter
TJeep_1999
2015 JK Wrangler
I am looking to re-gear my 3.07 D35. After pricing this out I thought I would look into the Ford 8.8 as an option. It's a bit more, but the main question I have now is will it work with my existing rims/tires?
I know the 8.8 is shorter:
Ford 8.8 WMS is 59 5/8 - Stock TJ is 60.5
I also know my 31x10.5R15's are already pretty close especially with the 5.5" Backspacing on a 15x7 rim.
I have seen a few threads where tires have rubbed on the upper rear spring perch and destroyed the tire.
Anyone running this set up now w/o issue? Thanks!
TJeep_1999 is offline
post #2 of 3 Old 06-25-2011, 12:00 AM
liftedon37s
The ford axle is only I believe 5/8 narrower than the Dana 35. You could also take a tape measure and see how much too
You have between the tire and spring perch. You could get spacers or a super 88 kit which would make the 8.8 factory width. Instead of a new axle You could look into a super 35 alot of guys run those with success. "
If you don't plan on going 33 to 35's the ground clearance you loose with the 8.8 is killer. I drag my 8.8 on alot of rocks sitting on 33's.
It has some things done to it.
liftedon37s is offline
post #3 of 3 Old 06-27-2011, 07:51 AM Thread Starter
TJeep_1999
2015 JK Wrangler
Not sure why I didn't think to ask about clearance... Thanks for the heads-up and the info!
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 05:23 PM
tires on stock grizzly rims talon282 TJ Wrangler Technical Forum 17 01-22-2010 09:48 PM
Anyone put different tires on the stock 16" rims? McKBrew JK Wrangler Technical Forum 3 12-08-2009 12:31 PM
Backspacing on Stock Grizzly Rims? Drjones266 TJ Wrangler Technical Forum 2 04-11-2004 08:16 PM
33" Tires on stock rims TJ LUVER TJ Wrangler Technical Forum 6 03-09-2003 02:18 PM
