Will an 06 soft top fit on an 01? - JeepForum.com
post #1 of 8 Old 04-14-2013, 04:25 PM Thread Starter
TJJeepJosh
I own a 2001 Sahara and found a soft top on craigslist that came off of a 2006. Its a good price so I want to buy it but will it fit?
I've seen the technical threads on this and there doesnt seem to be too much differences.
"Soft Top
* 97-00 - standard material
* 01-02 - 4-ply sailcloth
* 03-06 - 3-ply sailcloth - NOTE: Change in driver's side window: male zipper is now on window, female zipper on the top, previous years (97-00) were vice-versa."
From another thread.
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 8 Old 04-14-2013, 05:43 PM
02tjsport
2014 KL Cherokee
Yes it fits. I put an 05 soft top on my 02 no problem.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline
post #3 of 8 Old 04-14-2013, 06:00 PM Thread Starter
TJJeepJosh
Thought so. Just wanted to make sure thanks for confirming
post #4 of 8 Old 04-15-2013, 05:36 AM
wesboy
I have an 06 top on my 97.
Always been happy with it but wondered if the fit could be a bit better - my top seemed a bit more 'relaxed' than 06 tops I've seen on 06 TJs.
So I took off my 97-02 rollbar brackets and put on some 03-06 rollbar brackets.
The later model brackets stick out a bit further - this has resulted in the top being really taut. The sail panels now feel almost solid and the rear windows are less prone to flapping.
97 TJ Sport 4.0L Auto RHD
wesboy is offline
post #5 of 8 Old 04-15-2013, 07:08 AM Thread Starter
TJJeepJosh
That seems like an easy fix. Where did you find the 03-06 rollbar brackets? If not in a store there's probably some in a junkyard somewhere.
post #6 of 8 Old 04-15-2013, 10:04 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
They are around but the sellers seem to think they are made of gold.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 8 Old 04-15-2013, 08:12 PM Thread Starter
TJJeepJosh
Just put on my top today. It actually fit very well. Actually seemed tight to me. Although I've never put a soft top on before so maybe that's just how they are. Only piece I'm missing is the tailgate bar. Which I realized wasn't there after buying it
post #8 of 8 Old 04-16-2013, 06:00 AM
wesboy
I got my late model rollbar brackets here - but you are good to go without them.
http://www.jeep4x4center.com/mopar/j...p-hardware.htm
Like I said, I was always happy with the fit - only noticed the difference when I was up close and personal with an 06 TJ.
You will find tailgate bars in that link too - I'm sure there's cheaper alternatives if you have time to look for them
wesboy is offline
2001 , 2006 tj , help please , question , soft top compatibility
