Will an 05 Wrangler Unlimited 44's bolt into a 99 wrangler? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Will an 05 Wrangler Unlimited 44's bolt into a 99 wrangler?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 01-08-2009, 08:26 AM   #1
oneslowz28
As the title states. i have a killer deal on a pair of them and would like to know if they would bolt in with no problems. Thanks
oneslowz28 is offline   Reply With Quote
Unread 01-08-2009, 08:37 AM   #2
472cid
yea my 97 has 05 rubicon axles bolted right in real easy
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline   Reply With Quote
Unread 01-08-2009, 08:43 AM   #3
oneslowz28
thats awesome Thanks So there is no difference other than gearing for a 05 unlimited.
Unread 01-08-2009, 09:15 AM   #4
472cid
unlimited get 44 rear standard and prob different gearing yes
Unread 01-08-2009, 09:29 AM   #5
mdm
Farm Wheeler
Originally Posted by oneslowz28 View Post
...i have a killer deal on a pair of them and would like to know if they would bolt in with no problems...
Unless the donor vehicle is a Rubicon you won't be getting a pair of D44 axles out of it. Unlimited TJs have D44 rear and D30 front, 3.73 gears. If the donor is a Rubicon Unlimited it will have D44 front & rear with 4.10 gears.
mdm is offline   Reply With Quote
Unread 01-08-2009, 11:07 AM   #6
spyder6
Diddy Did It
spyder6's Avatar
it also has disk brakes, you may need to change your brake lines in the rear for those.
'12 Jeep Wrangler Unlimited Rubicon | sPOD4x4 | SprintBooster | AEV | AFE | EVO | Aeroforce | HotHeadz | Cobra | Firestik | Currie | Nth° | ROKMEN | Poison Spyder | Motive Gear | Trucklite | DynaTrac | MOPAR | BILSTEIN | Eibach | Trasharoo | GOESKE | Synergy | WARN | Spydura | OR-FAB | Artec | Nemesis | RIGID | Black Diamond | PowerTank | Mav02 | SpringTail |
Sonic Build
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote
Unread 01-08-2009, 11:11 AM   #7
472cid
hopefully they leave the hose on it so unscrew hard line at the frame and install new hose from the new axle, bleed brakes and go. It was an easy swap on mine and the e brake cables are different so hopefuly get those too.
Unread 01-08-2009, 11:11 AM   #8
oneslowz28
$2500 is a good deal for them right? 3.73 with rear posi?
Unread 01-08-2009, 11:16 AM   #9
joe130
Not in my opinion. I got a set of Rubi ones for $2K which had 4.10s and the lockers in them. You can find them if you look around. 3.73s won't get you very far in upgrading tires and wheels, also. You may just be buying axles that you're going to have to put numerically higher gears in later.
If you fill in your profile, we can help you more.
joe130 is offline   Reply With Quote
Unread 01-08-2009, 11:25 AM   #10
472cid
sounds high to me. rubi axles could be bought for around that
Unread 01-08-2009, 11:33 AM   #11
472cid
http://nashville.craigslist.org/pts/969565754.html
Unread 01-08-2009, 01:06 PM   #12
tjthorson
tjthorson's Avatar
Sounds high for stock axles. And - if they are 3.73s - its going to be a 44 rear and a D30 front (same as you have now....)
If he wants to sell the rear only (if your front is already a 3.73) for $800 or less - THEN its a killer deal.
$2500 for both - not a killer deal.... You could buy a nice, built, locked and loaded rear D44 for that, and have mod money left over.
If you really want to spend $2500 and get 2 axles - you should be able to find a rubi pair for that.
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! -> http://www.forgethannah.com
http://www.toddsplace.com
tjthorson is offline   Reply With Quote
