Wierd Vibrations after wheeling.... - Page 2 - JeepForum.com
post #16 of 18 Old 08-12-2013, 03:54 PM
hustler905
Originally Posted by Salgreatest9 View Post
Are they difficult to install ?
If you know how to read, and have a good set of external snap-lock ring pliers (there are a lot of similar pliers out there, look carefully at the pictures in the instructions and buy a good set for the intended purpose) you will be just fine installing a SYE yourself, in one afternoon.
I'd also recommend a stubby 9/16" ratcheting wrench for reaching some of the tighter clearance bolts to remove the TC from your Jeep.
hustler905 is offline
post #17 of 18 Old 08-12-2013, 05:33 PM
tjsean0308
I concur and will take 10-1 odds you bent the output shaft. So make sure you get a good SYE that includes a shaft, do not be tempted by the cheaper hack and taps. On the plus side you can probably ditch the t-case drop and gain some clearance now. You will need upper adjustable control arms to dial the pinion angle.
tjsean0308 is offline
post #18 of 18 Old 08-17-2013, 12:06 AM
Salgreatest9
Well thanks guys for all the info, always much appreciated. I ended up buying a procomp cv driveline and a sye kit with a short shaft. I payed 730 for both and 400 for labor. No vibration so it's running like a champ but for sure has been the most expensive wheeling trip I have ever had.
Salgreatest9 is offline
vibrations , t-case , t case , transfer case , tj , wrangler , wheeling
vibrations lawson1273 TJ Wrangler Technical Forum 2 06-18-2009 01:14 PM
bad vibrations tj4fun TJ Wrangler Technical Forum 2 01-19-2008 11:48 PM
Vibrations smunns TJ Wrangler Technical Forum 5 02-26-2007 07:49 AM
4 wd Vibrations TBoe TJ Wrangler Technical Forum 2 02-07-2007 05:50 PM
Vibrations??? dompaz YJ Wrangler Technical Forum 3 11-07-2005 05:42 PM
