wierd stalling issue - JeepForum.com
post #1 of 9 Old 05-12-2008, 05:20 PM Thread Starter
97tjtom
whenever i slow down in gear whether on the brakes or just engine braking (like to a stop) as soon as i push in the clutch, the revs fall all the way and i stall. if i push the clutch and then slow down, the revs will go slightly below normal idle but then come back up and be normal. what sensor is going bad?
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #2 of 9 Old 05-12-2008, 07:48 PM Thread Starter
97tjtom
bump please
97tjtom is offline
post #3 of 9 Old 05-12-2008, 10:45 PM Thread Starter
97tjtom
what would cause the engine to stall with reverse load(?) on it?
97tjtom is offline
post #4 of 9 Old 05-16-2008, 06:42 AM
Aaron1
On occasion I have the same issue with my 97 TJ. I've noticed that when this occurs, my speedometer fluctuates from 0 - max, and sometimes stays at 0 even when I am driving. Also my odometer does not work when the speedometer is acting up... Really sucks
Aaron1 is offline
post #5 of 9 Old 05-16-2008, 08:58 AM
Wif
Wif's Avatar
I would suspect the TPS.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #6 of 9 Old 05-16-2008, 09:20 AM
jneal
Nice....Keep Wheelin!
jneal's Avatar
TPS or speedo gear. Mine did that when my speedo gear got chewed up. check the plug to the gear and pull the gear to see if it is ok. make sure it is in the correct position as well.
Thanks
jneal
Twitter.com: jnealgoggins
Originally Posted by Beefstew View Post
You have nothing... You are a like a culture of ketchup mold... You are completely useless to everyone in the world!!!
Originally Posted by workinprogress View Post
Hey Rob, can you do me a favor and stop quoting the retard? I have him on my ignore for a reason.:thumbdown:
jneal is offline
post #7 of 9 Old 05-19-2008, 05:50 AM
Aaron1
Where would the Speedo gear / cable located at on the engine?
Aaron1 is offline
post #8 of 9 Old 09-23-2012, 08:37 PM Thread Starter
97tjtom
its been a while, but the cause of this was the speedo position.
97tjtom is offline
post #9 of 9 Old 09-24-2012, 03:21 AM
Jonny Jeep
Jonny Jeep's Avatar
As you are off throttle the IAC is controlling the engine speed. It might be sticking a bit. Might be time to clean the IAC and throttle body.
Jonny Jeep is offline
Wierd electrical/light issue... help! MikeyJ YJ Wrangler Technical Forum 6 03-23-2009 12:04 PM
Stalling Issue Flyersdjh TJ Wrangler Technical Forum 1 07-27-2008 02:27 AM
lift= wierd steering wheel tire issue? brinoff YJ Wrangler Technical Forum 3 03-16-2007 12:34 PM
wierd steering issue toates89 YJ Wrangler Technical Forum 11 10-22-2006 07:33 PM
Wierd Fuse Issue...HELP. blakkbelt YJ Wrangler Technical Forum 1 11-29-2005 05:23 PM
