Wierd shifting question???? - JeepForum.com
post #1 of 8 Old 06-27-2004, 03:27 PM Thread Starter
Gatormoots
I will try to explain as best i can. It just seems that when I shift into 2nd, 3rd, and 4th that there is not a nice smooth feeling, sorta like a little click or a mild mild grind feel just for a split second. I don't remember it before the 2"bb and 1" body lift plus a tc drop. I have adjusted my shifter so that works perfectly with the tc drop, also it doesn't happen every shift. So is this just normal or does something need to be adjusted. Any help would be great, I just want to make sure that I didn't screew something up.
Thanks
Gatormoots is offline
post #2 of 8 Old 06-27-2004, 03:49 PM
Dragonmaster
Dragonmaster's Avatar
kinda normal on an older transmission. If you haven't changed your tranny fluid in a while, some fresh fluid may solve it.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
post #3 of 8 Old 06-27-2004, 03:50 PM
MR.CLIFFORD
MR.CLIFFORD's Avatar
you can eliminate gear syncros by double clutching.
When you shift from 1st to 2nd just let the clutch out then press it in again to go into 2nd gear. If you don't grind then it is your syncros.
Custom signature
MR.CLIFFORD is offline
post #4 of 8 Old 06-27-2004, 04:23 PM Thread Starter
Gatormoots
The jeep is brand new?
post #5 of 8 Old 06-27-2004, 05:56 PM
Dragonmaster
Ouch, maybe your clutch fluid is low then???
post #6 of 8 Old 06-27-2004, 07:07 PM Thread Starter
Gatormoots
I checked that and it looked ok???
post #7 of 8 Old 06-27-2004, 08:27 PM
RC46VF
RC46VF's Avatar
I have just bought a brand new jeep ( I haven't lifted it or anything) and I have a similar problem. Not so much a grinding though. Every time I shift up to 2nd, 3rd or 4th there seems to be a split second hesitation and a slight noise. I have tried varying my clutch/throttle usage and can get it to shift smooth but not often. I have noticed the clutch engagement is quite different compared to my brothers 2002. There are a few posts here describing similar problems and when my brother drove my jeep it was very obvious to him. I called the dealer and they said drive it a little longer and let the tranny break in some more. I don't know yet but I've got a feeling there will be a T.S.B for this within the year. Good luck. If ya find out what it is, lemme know. I actually have a post asking about this.
RC46VF
2004 Wrangler Sport
4.0L 5speed
Bright silver metallic
30" tire package ( I know, small )
3.73 gears Dana 44 rear
In other words bone stock, but its better stock than most vehicles fully loaded :)
"I'm drivin' the jeep while the bike gathers dust."
RC46VF is offline
post #8 of 8 Old 06-28-2004, 02:07 PM Thread Starter
Gatormoots
That is exactly how it feels! Not really a grind but a hesitation and not perfectly smooth.
Another TPS question..Except wierd slkakaoki TJ Wrangler Technical Forum 20 07-30-2009 08:13 AM
wierd oil question johnnyfitz14 YJ Wrangler Technical Forum 9 11-19-2008 05:00 AM
wierd wobble question westmichjeeper TJ Wrangler Technical Forum 3 01-09-2008 05:00 AM
wierd question.. Squeeky TJ Wrangler Technical Forum 20 12-30-2007 12:42 PM
hmm wierd question? eclipse27 TJ Wrangler Technical Forum 16 09-03-2007 07:12 PM
