Why rebuild stock front drive shaft? - JeepForum.com
post #1 of 8 Old 11-27-2013, 06:45 AM Thread Starter
Ross
Less than a year ago my T-case had to be rebuilt. When I started poking around looking for a reason I found a small rip in the rubber boot of my front drive shaft. When I dug deeper I found those splines had jammed up. After allot of penetrating oil and beating the splines came loose. I also had taken a hard hit under the jeep and had broken a mount down there. Not sure which one of these, a combination of both or something entirely different lead to the destruction of my T-case.
I remove yoke every month or so and faithfully keep the splines lubricated and check things often to make sure drive shaft know moves as it should.
Very recently I heard a new sound coming from around the drive shaft and had vibes at very low speed. I thought I was the CV joint and planned on rebuilding it or just getting a new front drive shaft (because of some other concerns).
Last night after digging around I noticed more movement where the yoke goes into the drive shaft. I took the yoke off and noticed all the blue Teflon (or whatever crap) has completely worn off. I packed it with grease and but it back together. No more vibes or noise. This is a very temporary “fix” but it helped me to at least find my problem.
Is the coating wearing off a common problem with the stock drive shaft? Because of this is it really worth it to rebuild the CV in a stock shaft?
Is this a common problem with the stock drive shaft? Because of this is it really worth it to rebuild the CV in a stock shaft?
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #2 of 8 Old 11-27-2013, 07:24 AM
Ben
I've redone a few shafts, and that blue stuff works great for maybe 100,000 miles, but, once it gets to the point where that slip siezes, you gotta pick all that stuff out. A utility knife works pretty good at getting it out of there. Then pack it with grease like you said. Problem is, that's not going to get you too far down the road before the grease works its way out of there and you have metal on metal there, then, it'll start to gall out, and that shaft is toast.
So, is it worth it to rebuilt the CV?
That's your call, I have a bunch of XJ front shafts in my basement, and use the CV parts from them, I even cut them down to make rear shafts. It takes about an hour or two to put one together with all the right tools. So, for me it's worth it, even if I'm only getting 10-20k out of the shaft, spending $25 for a junkyard shaft and a few hours rebuilding it is worth it over spending $300 for a new aftermarket one. I can't see putting the money out when I've done this to one:
Ben is offline
post #3 of 8 Old 11-27-2013, 09:15 AM
Hosejockey61
Originally Posted by wkdeuce View Post
i can't see putting the money out when i've done this to one:
strong work!!!
Hosejockey61 is offline
post #4 of 8 Old 11-27-2013, 09:23 AM
Garza
Call Tom Woods, get a replacement, quit worrying about it. Your grease fix won't last a week and it will all end up on everything under your Jeep. NO sense in rebuilding a stocker for what a replacement will cost.
Garza is offline
post #5 of 8 Old 11-27-2013, 09:29 AM
hustler905
My double cardan is a little crunchy unless rammed full of fresh grease.
My slip/splines are a little junked up.
My driveshaft needs a balance.
I'm in the same boat, and think I will go with a complete aftermarket shaft. I think that in 240,000 km my stock one is just beat. There's not much left to save at this point.
hustler905 is offline
post #6 of 8 Old 11-27-2013, 09:47 AM Thread Starter
Ross
I am think of going with Tom Woods after reading about it on Stu's page.
I had an older Currie drive shaft that had that Teflon crap and it jammed up, I am assuming Tom Wood drive shaft is one you can grease. As far as throwing grease around, that is just a little more rust protection.
Ross is offline
post #7 of 8 Old 11-27-2013, 10:52 AM
marka2k
2006 WK
Front Shaft from TW is greasable, standard zerk on the front, and needle toward the TC.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #8 of 8 Old 11-27-2013, 10:55 AM
2k2wranglerx
I had the same issue when I got my TJ. the front shaft was too short and needed rebuilt.
by the time I did all that I was almost at the same price as buying a new one from Tatton (which I think was 230 shipped, but don't quote me on that).
been very pleased with their stuff.
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
