Quantcast Why get a tire carrier? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Why get a tire carrier?
Old 06-11-2009, 12:46 PM   #1
tavic
2010 JK Wrangler
I'm looking to add a lift in the near future, allowing me to run 32" to 33" tires. Why would I need a tire carrier? The hinges on the tailgate appear to be pretty beefy and I have seen replacement door mounted carriers to allow larger tires.
tavic is offline   Reply With Quote
Old 06-11-2009, 12:49 PM   #2
Clear Lake Jeep
Where'd all my money go??
Clear Lake Jeep's Avatar
You just nailed it there partner... The weight of the larger tires WILL end up messing your stock door up. Why risk it? Spend the extra scratch, get a heavy duty bumper w/ tire carrier, and enjoy the Mod!
Next thing on my list.... Spare Axle Shafts!
Clear Lake Jeep is offline   Reply With Quote
Old 06-11-2009, 12:59 PM   #3
quattrogato
If done correctly, by modifying the rubber bumpers on the tailgate so they continue to contact/support the spare tire and keep it from moving around you can easily carry a 32" tire - I have been doing so with no problems what so ever - in fact, since my 32 sits just on my rear bumper, it is supported better than stock. If you add a 1" body lift and/or have a less backspaced wheel, it is possible to carry a 33" tire. Bigger than that I personally would not go, but others have.
Chris B.
Evergreen, Colorado
2000 Sport - details in profile.
quattrogato is offline   Reply With Quote
Old 06-11-2009, 01:07 PM   #4
Imped
TITS
Imped's Avatar
Personally, I got the carrier for a couple reasons. I knew that I was going to run 35s in the future (am now) so the stock carrier was out of the question. Secondly, I dislike the look of the dinky stock bumper and much prefer a nicer aftermarket unit. Third, an aftermarket tire carrier mounts the spare up higher, meaning I don't have to worry about the tire scraping on a steep incline/decline, and I much prefer the look of a high-mounted spare. I believe that anything over a 31" tire should be mounted on a bumper-mounted tire carrier.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 06-11-2009, 01:18 PM   #5
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
No reason.A 33" tire on stock carrier for over 3 years with no problems.
No BL or BS here.
TheBoogieman is offline   Reply With Quote
Old 06-11-2009, 01:47 PM   #6
Hesher420
!!! SLAYER !!!
Hesher420's Avatar
With anything over a 31" spare, you run the risk of deforming your tailgate/hinges. Yes, some do it with no problems, so the choice is up to you. Do YOU want to risk it?
FOR SALE*NIB*TJ CHOME GRILL OVERLAYCLICK HERE
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Old 06-11-2009, 01:49 PM   #7
xxxflhrci
You can get by with a larger tire on your stock carrier if you never hit rough trails. Off-road, the bigger tire will likely wreck your tailgate sooner or later.
xxxflhrci is offline   Reply With Quote
Old 06-11-2009, 01:50 PM   #8
lumpster
lumpster's Avatar
ive run 33's on the factory spare tire mount for a long time on my old jeeps, never had a problem, never had to adjust anything due to sagging or deforming. as long as they rest against the rubber bumpers, it will last a long time.
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Old 06-11-2009, 01:51 PM   #9
lumpster
lumpster's Avatar
Wait to see if Blaine responds, his wifes rig runs a spare on the tailgate, NP. you cant get much rougher than JV, unless its high speed.
Want to STOP?
Old 06-11-2009, 01:59 PM   #10
03rubiconMG
you do not need a tire carrier with a 32 or 33, i ran a 33x12.5.15 TSL radial on my tail gate for a year and a half. all i did was put spacers in so that all those little rubber pieces that keep the tire from bouncing around are touching the tire,
if you dont extend those spacers you will have tailgate damage.
2003 white rubicon on 37s
http://farm4.static.flickr.com/3374/3258900652_92376a0a33_o.jpg
03rubiconMG is offline   Reply With Quote
Old 06-11-2009, 02:00 PM   #11
BloodThirsty
Blue On Black
BloodThirsty's Avatar
I run a 32 on the stock carrier. It's not on the rubber bumpers. How do I change that?
BloodThirsty is offline   Reply With Quote
Old 06-11-2009, 02:05 PM   #12
03rubiconMG
still use the rubber bumpers just find something to space them out, hockey pucks work, but you can probably find multiple things you could use.
Old 06-11-2009, 02:52 PM   #13
quattrogato
Again, if properly modded for your spare - up to a 33" tire IMHO, unless you tail-stand your Jeep on the spare, or back it into an obstacle, your tailgate will be fine, regardless of the terrain.
Chris B.
Evergreen, Colorado
Old 06-11-2009, 04:24 PM   #14
LJ_Cool
Generally, a 33" tire is about 15 lbs or so heavier than a 30" of the same tread pattern.
So if it's mounted properly, and tight against the rubber pucks, the extra 15 or 18 lbs, shouldn't be too detrimental.
I think little kids hanging off of it when it's open, or standing on the tire to wash the roof, might be more stressful.
have a good one
2006 TJ Unlimited (Midnight Blue #888)
58k - 2" lift, riding on 31's with terraflex rocker armor
LJ_Cool is offline   Reply With Quote
Old 06-11-2009, 04:39 PM   #15
BYuen
Wahoowa
BYuen's Avatar
I ran my 33" spare on the stock carrier for a while. It did warp the gate hinges a little and it doesn't completely seal at the bottom of the gate. My 33" spare was even pretty light. It was an AT tire on the stock aluminum wheels. I wouldn't recommend running a 33" tire with the stock carrier permanently and definitely nothing larger than a 33" tire.
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Glock Forum
