why doesnt everyone do this with their lca's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > why doesnt everyone do this with their lca's
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-16-2010, 09:55 PM   #1
bandit455
i noticed it in the re bushings thread, i am not so sure if I would move the frame side down, but the axle side up seems like a no brainer
than you could trim that bracket up and box it in
Eagle scout jeeper #10
my build thread
The Things We Make, Make Us
bandit455 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 09:59 PM   #2
lumpster
lumpster's Avatar
i wouldnt consider it a good idea, for one your messing with the suspension geometry, 2 your making the frame mounted hanger weaker by going closer to the edge of the bracket, your also decreasing seperation of the control arms, putting more stress on the brackets.
Why didnt the owner of this jeep trim up the axle side mounts? that looks silly hanging down like that, but if it were me, i would put it all back to the stock holes.
lumpster is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 10:02 PM   #3
COLOUXJ
2010 JK Wrangler
From how it looks there it seems like the output from the pinion is pointing down quite a bit more.
COLOUXJ is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 10:03 PM   #4
bandit455
I could see the increased stress on the frame bracket, but the axle one, your bringing it closer to the "fulcrum" arent you?
and if strength is a concern you could box the bracket, this would be a good idea anyhow since there flimsy
how does less seperation increase stress on brackets?- A serious question because i know little about link seperation other than you want some and it helps with your squat/anti squat
my build thread
Unread 02-16-2010, 10:05 PM   #5
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
people don't do that for two reasons -
1. you're screwing with suspension arcs
2. you're GREATLY increasing the amount of stress on the mounts.
see here:
http://www.jeepforum.com/forum/f9/br...racket-905624/
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 10:08 PM   #6
ptwelve
Gee I'm a tree.
ptwelve is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 10:08 PM   #7
bandit455
these pics are of a nth kit also, is this something that was in nth degrees old sa lift instructions?
my build thread
Unread 02-16-2010, 11:23 PM   #8
mrblaine
Wizard of Brakes
mrblaine's Avatar
This thread amuses me.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 02-16-2010, 11:51 PM   #9
mudb8
want it rite or rite now?
mudb8's Avatar
it is for the nth when using a stinger, not with the upper ca's.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 02-17-2010, 12:03 AM   #10
lumpster
lumpster's Avatar
i dont see a stinger anywhere on that jeep.
Unread 02-17-2010, 05:20 AM   #11
bandit455
^ me either
thanks for making some sense of this
my build thread
Unread 02-17-2010, 10:25 AM   #12
SpeedJeep
SpeedJeep's Avatar
Correct. Nth had something like a rear tri-link (and they may have called it a stinger) but relocating the lower arms like this was part of the instructions.
SpeedJeep is offline   Reply With Quote Quick reply to this message
Unread 02-17-2010, 10:43 AM   #13
SpeedJeep
SpeedJeep's Avatar
This thread smells of internet scare tactics and rumors already.
Unread 02-17-2010, 12:33 PM   #14
shrubeck
I did that with mine as an experiment. Yes it screwed with the geometry... correctly. It reduced the unbelievable amount of antisquat you get with a TJ short arm lift, and put it in line with where a properly setup suspension should be. It litterally made the difference between easily climbing obstacles and nearly flipping over backwards. Also the TJ tire-pick trick (lifting the left front off the ground when accelerating around a corner) is totally gone.
However....
It does stress the mounts and does very little to control wrap. Even with all new bushings and good rod ends, the axle wraps a few degrees. It was a good proof of concept test to see what problems the excessive antisquat was causing, but the tradeoffs are not totally worth it. Now I'm splitting the difference and using the lower hole on the frame end, and the stock hole on the axle end. This helps the geometry a bit without killing the vertical separation of the links.
That's what she said.
shrubeck is offline   Reply With Quote Quick reply to this message
Unread 02-17-2010, 01:29 PM   #15
bandit455
hmmm good info
i was thinking of doing it the other way and just raising the axle end and then boxing it in to help alleviate the stess off the mount
my build thread
