why doesnt everyone do this with their lca's - JeepForum.com
post #1 of 29 Old 02-16-2010, 08:55 PM Thread Starter
bandit455
i noticed it in the re bushings thread, i am not so sure if I would move the frame side down, but the axle side up seems like a no brainer
than you could trim that bracket up and box it in
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #2 of 29 Old 02-16-2010, 08:59 PM
lumpster
lumpster's Avatar
i wouldnt consider it a good idea, for one your messing with the suspension geometry, 2 your making the frame mounted hanger weaker by going closer to the edge of the bracket, your also decreasing seperation of the control arms, putting more stress on the brackets.
Why didnt the owner of this jeep trim up the axle side mounts? that looks silly hanging down like that, but if it were me, i would put it all back to the stock holes.
lumpster is offline
post #3 of 29 Old 02-16-2010, 09:02 PM
COLOUXJ
2010 JK Wrangler
From how it looks there it seems like the output from the pinion is pointing down quite a bit more.
COLOUXJ is offline
post #4 of 29 Old 02-16-2010, 09:03 PM Thread Starter
bandit455
I could see the increased stress on the frame bracket, but the axle one, your bringing it closer to the "fulcrum" arent you?
and if strength is a concern you could box the bracket, this would be a good idea anyhow since there flimsy
how does less seperation increase stress on brackets?- A serious question because i know little about link seperation other than you want some and it helps with your squat/anti squat
post #5 of 29 Old 02-16-2010, 09:05 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
people don't do that for two reasons -
1. you're screwing with suspension arcs
2. you're GREATLY increasing the amount of stress on the mounts.
see here:
http://www.jeepforum.com/forum/f9/br...racket-905624/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 29 Old 02-16-2010, 09:08 PM
ptwelve
Gee I'm a tree.
ptwelve is offline
post #7 of 29 Old 02-16-2010, 09:08 PM Thread Starter
bandit455
these pics are of a nth kit also, is this something that was in nth degrees old sa lift instructions?
post #8 of 29 Old 02-16-2010, 10:23 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
This thread amuses me.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #9 of 29 Old 02-16-2010, 10:51 PM
mudb8
want it rite or rite now?
mudb8's Avatar
it is for the nth when using a stinger, not with the upper ca's.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #10 of 29 Old 02-16-2010, 11:03 PM
lumpster
lumpster's Avatar
i dont see a stinger anywhere on that jeep.
lumpster is offline
post #11 of 29 Old 02-17-2010, 04:20 AM Thread Starter
bandit455
^ me either
thanks for making some sense of this
post #12 of 29 Old 02-17-2010, 09:25 AM
SpeedJeep
SpeedJeep's Avatar
Correct. Nth had something like a rear tri-link (and they may have called it a stinger) but relocating the lower arms like this was part of the instructions.
SpeedJeep is offline
post #13 of 29 Old 02-17-2010, 09:43 AM
SpeedJeep
SpeedJeep's Avatar
This thread smells of internet scare tactics and rumors already.
post #14 of 29 Old 02-17-2010, 11:33 AM
shrubeck
I did that with mine as an experiment. Yes it screwed with the geometry... correctly. It reduced the unbelievable amount of antisquat you get with a TJ short arm lift, and put it in line with where a properly setup suspension should be. It litterally made the difference between easily climbing obstacles and nearly flipping over backwards. Also the TJ tire-pick trick (lifting the left front off the ground when accelerating around a corner) is totally gone.
However....
It does stress the mounts and does very little to control wrap. Even with all new bushings and good rod ends, the axle wraps a few degrees. It was a good proof of concept test to see what problems the excessive antisquat was causing, but the tradeoffs are not totally worth it. Now I'm splitting the difference and using the lower hole on the frame end, and the stock hole on the axle end. This helps the geometry a bit without killing the vertical separation of the links.
That's what she said.
shrubeck is offline
post #15 of 29 Old 02-17-2010, 12:29 PM Thread Starter
bandit455
hmmm good info
i was thinking of doing it the other way and just raising the axle end and then boxing it in to help alleviate the stess off the mount
33's and LCA's TJW909 TJ Wrangler Technical Forum 5 03-28-2008 12:04 PM
Need for adjustable LCA's?? the_ronster TJ Wrangler Technical Forum 7 12-13-2004 02:03 PM
Adjusting the LCA's Jpfrk TJ Wrangler Technical Forum 2 07-08-2003 03:11 PM
Broken TJ LCA's foreverjeepin TJ Wrangler Technical Forum 20 05-20-2003 05:56 PM
Adustable LCA's blacktj TJ Wrangler Technical Forum 9 03-20-2003 08:54 AM
