Why does water boil in my overflow tank - JeepForum.com
post #1 of 24 Old 07-19-2006, 10:52 PM Thread Starter
Fargo
I've had water boiling in my overflow tank 2 times now. Its time for me to figure out whats happening.
Here's a little history. I purchased my 99 Sahara about 3 years ago. I've been able to smell antifreeze on occation ever since I purchased it. Last winter I saw steam coming from the seams where the plastic top of the radiator meets the radiator. So at first I thought my radiator was shot. But then others have told me they will do this because the plastic and the metal expand at different rates. And it will be fine once its at operating temperature.
So whats the reason for water boiling in the overflow? I have never had water leak or lost any fluid. (Other than maybe minor amounts I thought was just evaporation.) I've also never noticed my temp gauge get anywhere near the red line. Only slightly over 210. Maybe 215. I checked the antifreeze with a gravity ball testor and it showed good to 260.
I did a search and tried to check some other things. I tried to check the fan clutch but I couldn't find how the clutch moved seperate from the fan. They seemed to be bolted together. But the fan itself turned with some resistance. I also tried to feel the top hose for water flow. I couldn't feel the water flow through it but after running the Jeep for some time the hose did get warm and I think the temp droped a couple of degrees after that. So I'm inclined to think that my thermostat is good. So did I check something wrong? Or is there another reason my water is boiling in my overflow tank? Thanks for the help.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #2 of 24 Old 07-19-2006, 11:08 PM
Doatman
Doatman's Avatar
Is your anti-freeze a 50%-50% mix? If not, see if you can make it so, and then replace your radiator cap; it is often overlooked as a culprit. It sounds like you have already looked at the obvious, like clutch, serpentine belt, thermostat, clogged radiator core, etc. Good luck.
Doatman is offline
post #3 of 24 Old 07-19-2006, 11:30 PM
IGotADisneyJeep
IGotADisneyJeep's Avatar
There is air getting into your system. You should check the level of antifreeze in your sysyem.Check to see if the over flow is dry then start to drive when your engine is still cold and drive it for a hour or so then stop your jeep & see what happens. The antifreeze will come into the overflow & bubble up/boil. Then when it cools the antifreeze will go back. Perhaps the overflow its not filled to the correct level. The overflow should have levels marked as "Full & Fill" if its dry fill it up to "Fill" or just a tad bit higher with antifreeze. Try it again with the engine cold, drive it for an hour or so & see what happens. Hopefully it will not bubble/ boil in the overflow. If it does check other parts whats mentioned in the last post.
If you can... I suggest to drain all the antifreeze and buy a radiator cleaner & follow directions then fill it with clean antifreeze. Fill it to the correct level & hopefully all will work out.
Good Luck!
IGotADisneyJeep is offline
post #4 of 24 Old 07-20-2006, 07:18 AM
cincytj
cincytj's Avatar
get someone to pressure test your system and the CAP. dont forget the CAP becuase it is usually overlooked and usually the problem. Your system has to hold pressure because the pressure raises the boiling point of your coolant.
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
post #5 of 24 Old 07-20-2006, 07:54 AM
erickpl
erickpl's Avatar
Another simple explanation - water in your radiator is hotter than 212 degrees, the normal boiling point of water, but with the antifreeze and the higher pressure, the effective boiling point is much higher.
Once you get the antifreeze/water mix into the overflow, the pressure is much lower, making the boiling point lower, still higher than 212 most likely, but a lot lower than inside the radiator/cooling system in general.
That's the scientific explanation. Now as to why you have having cooling issues, I would suspect that you have either a gummed up thermostat, radiator core, or hoses, or a combination thereof.
Replacing the t-stat is VERY easy, but be sure to get the proper one for your Jeep. If you replace the radiator, go aftermarket and get an all metal one, none of that plastic/metal binding that DC uses on Jeep radiators.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #6 of 24 Old 07-20-2006, 09:05 AM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
Coming from my first love - turbo buicks - I have seen this many times.
Check all the easy stuff above - then a compression test is in order. A blown headgasket or cracked head will do the same thing. The hot exhaust gas leaking into a water jacket superheats the water and boils it....
I hope its as easy as a thermostat or cap - but don't drive it too much if you can't figure it out. Its not doing it because it doesnt like you - there IS a reason.
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #7 of 24 Old 07-20-2006, 11:04 AM
ncb76
ncb76's Avatar
x2
If you can see the coolant bubbling out/steaming from the radiator, it's not holding pressure.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #8 of 24 Old 07-20-2006, 11:12 AM
BEANS
BEANS's Avatar
You ether have a blown head gasket of a cracked head!
You are getting compression gases in the cooling jackets of your engine.
Pull your plugs and do a compression test.
2001 SPORT 4.0 AUTO EMPTY GAS TANK
2 1/2"O.M.E. 1"Body LIFT
33" DUNLAP'S
JSK QUICK DISCONNECTS THAT I'LL NEVER DISCONNECT
LIMITED SLIP WITH 4.11'S FRONT AND BACK
S.Y.E
7'6" SNOWAY POLY PLOW
Elect Radiator fan on a Delta control
Borla Header, Catback Exhaust By Volant 304SS
BEANS is offline
post #9 of 24 Old 07-20-2006, 11:30 AM
KaiserJeep
Your radiator is simply not holding pressure, in fact you saw steam escaping from the seam where the leak was. Because there is no pressure in the system, the coolant boils at a lower temperature. The steam escapes into the overflow bottle because it rises to the top of the radiator, then passes through the vent line to the bottom of the overflow bottle - that gives the boiling symptom.
Time for a cooling system refresh:
1) New radiator (many options, use the search feature)
2) New radiator hoses and clamps
3) New heater hoses and clamps (only under the hood)
4) New radiator pressure cap
5) New thermostat and gasket
6) Flush block and refill with 50/50 coolant and distilled water
7) New serpentine belt
While the belt is off, check for bearing play in the water pump. If you find some, it is the perfect time to do the pump and pump gasket.
You can do this yourself if you have a shady place to work. Make sure you have all the pieces needed. Be carefull when you do the heater hoses, the valves are plastic and break easily, so carefully slit the old hose and peal it off, don't pull.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #10 of 24 Old 07-20-2006, 01:32 PM Thread Starter
Fargo
I think I'll ignore this post because I don't like this answer
I really hope your wrong here. That does not sound good at all. But thanks for giving me another place to check.
6spd manual
Fargo is offline
post #11 of 24 Old 07-20-2006, 01:38 PM Thread Starter
Fargo
Do you feel pretty confident that this is the case? That I am loosing pressure at that seam. Or should I get a pressure check before I purchase a new radiator?
I did see the steam coming from the seam 1 time. And I can smell it from time to time. But I don't know where the smell is comming from. Is there any validity to those that say this steam is normal because the metal and plastic expand and contract at different rates until you are at operating temperature.
6spd manual
Fargo is offline
post #12 of 24 Old 07-20-2006, 01:52 PM
Wif
Wif's Avatar
If you have a blown head gasket or cracked head you will displace a lot of coolant into the overflow bottle. The exhaust gases will replace the coolant.
The level will rise and maybe blow coolant out over the engine bay. It will not all go back into the radiator when it cools down.
The coolant will start to darken up, and will smell funny.
If the rad cap is leaking, then the pressure will bypass the cap and coolant will overflow into the bottle, but only to the expanded level .. it will all be drawn back in when it cools down.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #13 of 24 Old 07-20-2006, 02:35 PM
KaiserJeep
Get a radiator pressure test if you want - it shoudn't cost anything. Or you could just wrap a cloth around the top radiator hose and squeeze it to feel for system pressure once the engine reaches full temperature - the hose will be stiff with pressure, squishy without pressure.
The leak could be a bad hose, a bad pressure cap, or even at the thermostat gasket. However YOU SAID you saw steam coming from the radiator seam and in spite of what you were told, that is NEVER OK. Check along that seam and you will probably see water marks from evaporating coolant which is the final confirmation.
The stock Jeep radiator is aluminum center core with plastic end caps. The caps have a plastic foam gasket and the core flange is simply crimped around the plastic flange. Yours lasted 7 years which is longer than most. Replace it with a quality aftermarket unit. Do your homework first - lots of threads in every Jeep Forum I read about radiators.
Gary
post #14 of 24 Old 07-20-2006, 02:37 PM
thesherm
thesherm's Avatar
My 98 has steamed slightly once in a while over the last five years, and I have also heard that it is due to the plastic/metal issue. about 4 years ago I replaced the water pump, flush & refill, thermostat and serpentine. just last month i did another flush & refill and new belt and of course inspected everything - no issues. just follow everyone's advice here on checking/testing to be certain that you have ruled those issues out. Kaiser's advice is excellent if your system is due for it
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #15 of 24 Old 07-20-2006, 06:47 PM Thread Starter
Fargo
The shop I called quoted me $20 for a pressure check. Thats why I wondered about getting it when I tend to think that is the problem. I did check the top hose a little bit last night and I couldn't feel any pressure. Once again leading me to think that is my problem.
I did see steam this winter and I can see evidence of water marks from coolant along the seam.
Acutally I think I've had a problem since I purchased the Jeep 3 years ago. Almost from day one I could smell coolant but never knew where it was coming from until I saw the steam last winter. Then this summer it boiled in the tank for the first time. That was when I really began to think I had a problem.
So I will double check the hose presure and maybe get a pressure check. But from what I've read. It sounds like I will be purchasing a radiator. I have already looked a little and found 3 core metal radiators at www.radiatorbarn.com and www.radiator.com. Are these reputable places to buy from? Is there anything in particular I should look for or ask about? I'm just trying to do my homework here. Which is a good brand. I think I saw CSF somewhere, are they any good?
Edit: Also where should I get the hoses from? Will auto stores carry them. Do I need a factory thermostat or can I pick that up at an auto store as well?
6spd manual
Fargo is offline
Should water boil in my overflow? WarrenW TJ Wrangler Technical Forum 75 08-08-2009 09:08 AM
Overflow Tank Tompatt YJ Wrangler Technical Forum 27 02-09-2009 06:03 PM
aftermarket radiator overflow tank/reservoir WillyB TJ Wrangler Technical Forum 2 05-12-2008 11:47 AM
Radiator fluid overflow to the Overflow Tank Thunderstrike TJ Wrangler Technical Forum 2 01-16-2007 08:17 PM
Gas Tank overflow Frederick TJ Wrangler Technical Forum 3 08-21-2006 08:12 AM
