Why does my cupholder boil water and mom's doesn't? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Why does my cupholder boil water and mom's doesn't?
OPTIC ARMOR WINDOWS all sale now !!!!!!!!Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Spartan Locker Special Forum Prices Dana 30 44 60 Ford 8.8
Unread 08-26-2013, 12:05 PM   #1
LiveAndLearn
Okay so my cupholder doesn't really make water boil, but I'm pretty sure it could lol but what can I put between the tub and the center console to prevent heat? I will say she has a body lift and I have a tummy tuck, so that might have something to do with it lol
1997 TJ - 4.25 lift, 4.88, D30 w/ Detroit, D44 w/ Superior'ed Detroit and 33 spline shafts, Currie track bar, Warn XD9000i, Currie Tire Carrier, full armor and tube fenders, full custom trunk, Tom Woods shafts, AA SYE, Currie control arms, and Rigid lights. BIG BLACK is my baby.
LiveAndLearn is offline   Reply With Quote
Unread 08-26-2013, 12:21 PM   #2
biffgnar
biffgnar's Avatar
So you did a mod that decreases airflow over hot things under jeep and moved those hot things closer to tub floor and she did a mod that allows for greater airflow over those hot things and moves the tub floor farther away and you don't understand the different results?
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote
Unread 08-26-2013, 01:47 PM   #3
tyvanwie
tyvanwie's Avatar
Lol this
MY BUILD THREAD
MY FITNESS LOG/TRANSFORMATION
JK AND TJ PARTS FOR SALE
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is online now   Reply With Quote
Unread 08-26-2013, 02:04 PM   #4
hustler905
Wow.
hustler905 is offline   Reply With Quote
Unread 08-26-2013, 02:18 PM   #5
Benderff
MEMBER
Benderff's Avatar
Live is always good for a laugh. I do give him some slack, since he was shot in the face.
Benderff is offline   Reply With Quote
Unread 08-26-2013, 03:07 PM   #6
dayriesw
dayriesw's Avatar
Need pics of mom and jeep for analysis.
Impact Orange LJ - DD...sitting low, flat bottomed, fully armored and locked on 35s
dayriesw is online now   Reply With Quote
Unread 08-28-2013, 05:22 PM   #7
LiveAndLearn
I'm glad my jokes make y'all laugh
Been a while since I've been on here, figured I'd ask a really technical question pics of mom with our new group shirts on lol
Unread 08-28-2013, 05:26 PM   #8
btn
Since the center console is hollow, you can unbolt it and stuff the inside with house insulation. You can fill the insulation around the shifters and levers as well.
2000 TJ, 4.0L, 4" short arm suspension lift, 35" tires, Rear D44 and front HP30 both with ARBs and chromo shafts, NV3550.
btn is offline   Reply With Quote
Unread 08-28-2013, 06:09 PM   #9
The_Dealer
2003 KJ Liberty
Cause she's way cooler? Go to Lowe's, get the garage door insulation that looks like bubble wrap with foil over it. Also get some foil tape, like the super sticky crap for metal ducting. Put it down like dynamat. Make sure to use acetone or denatured alcohol to prep the floor so the tape will stick. Put 2 layers down close to the tunnel. Reinstall carpet. Or use this stuff...
http://www.homedepot.com/p/t/1006612...1v&R=100661257
They also make it in 48"x6ft for 19.99
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline   Reply With Quote
Unread 09-03-2013, 01:04 PM   #10
TAS
Whem I removed my carpet, my cup holders no longer kept my beverage cold. Took out console and used that expanding insulation under the cup holders. problem solved.
BTW, kuddos to you for playing along and actually posting a pic of your mom. lol
Todd
98, I6, 4" RC Lift, 35's and a few other mods that get me there.
Tow rig - 12 F-350 4x4
TAS is offline   Reply With Quote
Unread 09-03-2013, 04:06 PM   #11
tdavid14
And she drives a Jeep? Wow!
Sent from my SPH-D710 using JeepForum
tdavid14 is offline   Reply With Quote
Unread 09-03-2013, 05:36 PM   #12
Jeepin72
Is it the weekend yet?
Jeepin72's Avatar
Get some heat shield like the stuff that follows the exhaust system and put in where ever it seems best. Most likely, under the tub, above the running gear.
Jeepin72's Build Thread
Jeepin72 is offline   Reply With Quote
Unread 09-12-2013, 02:42 PM   #13
LiveAndLearn
Just for giggles, I decided to insulate it. Went to an upholstery shop and they have me roll of this stuff for free. They said they put if between the floorboard and carpet in a car. So I cut it to size and really insulated the cup holder area. I used the spray on adhesive. If this doesn't work too well I'll take the console back off, and put a later of aluminum foil on-top of the insulation. Haven't taken the jeep out since I installed this but I will let y'all know how it does!
Unread 09-12-2013, 03:19 PM   #14
KMET
Isn't that at risk of catching fire?
More photos of Mom... (she's my age)
o6 LJ see profile...
KMET is offline   Reply With Quote
Unread 09-12-2013, 03:51 PM   #15
wage
X2 on the foil lined stuff from Home Depot. It absolutely worked for me. Keeps my cold adult beverages very cold. Now.... about Mom....Let me introduce myself.....lol...well almost kidding.
Good Luck...and if Mom really drives a jeep......Oh My.
wage is offline   Reply With Quote
