Why do I need a locker? I thought I had 4WD! - Page 3 - JeepForum.com
post #31 of 79 Old 11-07-2009, 07:51 PM
SunNuclear
Another thing to consider is this, when I had my 98 Z71 I put an ARB in the rear axle removing my limited slip diff. This was great off road but on road in the rain it sucked because it was now a one wheel wonder unless you had the diff locked. It was hard to take off from a light on wet tar without peeling out, when I had the stock limited slip in it was way better in that situation. So now my choice was to take off slow or keep locking and unlocking the diff.
Anyone here fly RC Heli's??????????
SunNuclear is offline
post #32 of 79 Old 01-19-2010, 12:22 PM
ticotj
Thanks for the helpful info. We need more topics like this.
ticotj is offline
post #33 of 79 Old 04-24-2010, 07:46 PM
Marholmes44
So after reading this in theory you can have a 2WD put manually lockers in it and be the same thing as 4WD correct?
Marholmes44 is offline
post #34 of 79 Old 04-24-2010, 09:07 PM
BWFBezerk
well...........the front won't be spinning, just both rear.
2004 TJ SE 2.4L 5-speed. 2.5" Rough Country Lift, 1.25" Rough Country BL, Rough Country Stinger, Rough Country Rocker Rails, 9,500LB Vortex Winch ($200 off eBay), 4' FireStik, CB, Dana 30/35 4.10's, front Aussie Locker. 33x12.50x15 Dakota A/T on 15" Canyons painted black, 1.5" wheel spacers. Remote Start. MCE Flatty Fenders. All work done by me, with some help from my friends.
Videos:
Pics:
Xbox: BWFBezerk
BWFBezerk is offline
post #35 of 79 Old 04-24-2010, 09:27 PM
Imped
Imped's Avatar
Try reading again. You're way off.
OlllllllO
IndyORV
Imped is offline
post #36 of 79 Old 08-03-2010, 12:11 PM
heethern
This is an awesome thread. Helped me out a lot. Thanks man!
heethern is offline
post #37 of 79 Old 11-13-2010, 06:51 PM
baritone_mike
Very good thread, I now understand why on a stock Jeep all 4 tires do not spin with 4 wheel drive.
The breaking trick is still used by the military. Does anybody know the actual name for the trick as I would like to read more about it and see if I can find a way to use 3 pedles with 2 feet.
baritone_mike is offline
post #38 of 79 Old 01-19-2011, 08:53 AM
rujji8
2011 JK Wrangler
it can usually handle a locker without problem with reasonably sized tires.
dose thirty threes fall into that category? After reading your write up I have chosen to just install lockers. And do you think a Dana 35 rear handle a manuel locker or is it still not a good idea
rujji8 is offline
post #39 of 79 Old 01-19-2011, 08:57 AM
rujji8
2011 JK Wrangler
rujji8 is offline
post #40 of 79 Old 01-19-2011, 08:57 AM
MO2500
Hand throttle
Instagram: @omsmike
MO2500 is offline
post #41 of 79 Old 01-19-2011, 09:01 AM
rujji8
2011 JK Wrangler
cuz you said lockers are good with reasonable tire size.dose thirty threes fall into that category? After reading your write up I have chosen to just install lockers. And do you think a Dana 35 rear handle a manuel locker or is it still not a good idea
rujji8 is offline
post #42 of 79 Old 01-19-2011, 10:01 AM
zjwn2
I have actually been really impressed on what I have been able to get through in just 2wd just by using the hand brake to help the stock LSD get power to the wheel with the traction. I was thinking of adding a locker to the front axle but in reading this I am a little confused in that if you do alot of driving in the snow/ice you do not want a front locker but would prefer a LSD instead or some type of manual locker?
zjwn2 is offline
post #43 of 79 Old 01-19-2011, 10:21 AM
kenmal
Yes little confused on this too.
kenmal is offline
post #44 of 79 Old 01-19-2011, 11:30 AM
MeltdWhiskey
here's a good video that may help explain what's going on..
you may want to skip ahead to the 2.5 min mark ..thats' where the good stuff starts
MeltdWhiskey is offline
post #45 of 79 Old 01-19-2011, 11:58 AM
FarmerinVA
Someone said your are way off. Actually, you're not so far off. A 4WD with open differentials will, in slippery conditions, only have two tires that really spin with power (one front, one rear). A 2WD with a locked differential in the powered axle will also have two tires that really spin with power (both rear, assuming you're rear wheel drive). A 4WD is always more versatile, generally safer at speed, and usually otherwise better (long list of reasons), but a locked 2WD isn't a crazy alternative for many run of the mill uses. A locked 2WD can be a pretty capable vehicle. Locking a 2WD vehicle is also generally cheaper than getting a 4WD option, for example in a Ford Ranger pickup.
When the axle is locked, it spins the wheels together at exactly the same speed, which causes lateral stability to decrease greatly -- you tend to slide sideways on snow (particularly, sideways down a hill or cambered street surface). If the wheels spin together but not at the same speed -- as can occur with an LSD -- lateral stability will improve. I say "can" because LSDs vary in their habits and you might find that they cost you some lateral stability. Sometimes an LSD will spin the wheels at exactly the same speed, sometimes not.
If it's a 4WD and you have a front selectable locker (the term "manual" is confusing, I think), put it in 4WD and just don't lock it, and you won't have these problems. You'll have the locker there when you want it -- if you get stuck -- and not there when it would make you nervous. If you have a front auto-locker, just don't put it in 4WD on snow. Or, do use 4WD but drive cautiously until you understand the autolocker's habits -- that's what most people do, and some folks report decent results.
I personally have not found side-slip from a selectable-locked front axle to be a major problem when cautiously driven at low speeds. I have not tried speeds above 15mph on slick mud or snow.
If you are looking for a way to travel fast over snow without side slip concerns, forget the locker, get this instead.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
