Who's installed LED's / LED Question?!?!?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Who's installed LED's / LED Question?!?!?!
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 01-25-2015, 06:22 AM   #1
FtDavisJeep
I'm looking at putting Red S/T/T LEDs in the back of the Jeep as well as my reverse lights. Do I need to install an Anti-Flicker module in-line for the S/T/T LEDS or will just changing the Flasher to a EP-26 LED be fine and fix any possible problems? Also do I need to put anything in-line for the White reverse LED lights, they will be separate from the Reds.
And then I plan on putting in some LED Headlights in and am also wondering if I would have to install something as well with them such as the Anti-Flicker Module or an in-line resistor or what?
Any Help would be GREATLY appreciated. I hate to buy any of this stuff install it and then two weeks later blow them, effectively blowing my money and time.
Thanks again Guys!!!
I Love Shenanigans!
FtDavisJeep is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 06:32 AM   #2
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
You will not need to do anything for your reverse bulbs.
Mail crawling.
MisfitSeven is online now   Reply With Quote Quick reply to this message
Unread 01-25-2015, 06:44 AM   #3
festerw
Only thing you'll need is the new flasher.
Hers - 2005 Jeep Grand Cherokee Laredo 3.7 4x4
Mine - 2003 Jeep Wrangler X
festerw is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 10:03 AM   #4
biffgnar
biffgnar's Avatar
The flicker issue is a JK problem.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 11:20 PM   #5
FtDavisJeep
So just on the Stop, Turn, Tail portion just the new flasher. What about head lights? If I install LED headlights will I need anything additional? From looking around it seems that the JKs need something like the Anti-Flicker thing but I haven't found anything for the TJ except stuff off of ebay and I don't trust that stuff. They'll say you need it or that its required but in reality it's all B.S. . They're just trying to sell you crap.
I Love Shenanigans!
Unread 01-25-2015, 11:35 PM   #6
aparke4
aparke4's Avatar
I used a thread on pirate
My 01 Tj has all leds in turn signals and brakes lights... Needs resistors and diodes wired in line to work right. Led headlamps and truck lite and are plug and play. Used gen right led flasher.
aparke4 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:48 AM   #7
Neil F.
Headlight flicker with LED headlights is JK only. Truck Like, Quadratec, Peterson, Speaker, Sylvania etc headlight are pluf and play.
You can't generalize ebay. I buy tons of stuff off ebay. The best price on Truck Lites is ebay.
Neil F. is offline   Reply With Quote Quick reply to this message
Unread Today, 04:06 AM   #8
FtDavisJeep
No, no I'm not generalizing ebay as a whole. There's some great folks on there, but there is a lot of them on there that are like that and It's hard to wade through all the "stuff" just to find the good folks. And the ones that claim they're the real deal, it's hurts the others when your trying to find quality products without the BS.
I Love Shenanigans!
Unread Today, 04:10 AM   #9
FtDavisJeep
Ok so for example on a set of white reverse LED's you need to put resistors and diodes wired in-line. Is this also required for the red Brake, Turn, Tail light? Also what resistors and diodes do you use? Do you happen to have that thread from the other forum?
I Love Shenanigans!
Unread Today, 05:17 AM   #10
festerw
No the only time those are needed is if you are replacing all turn signal bulbs and even then you only need them on the front. I have LED reverse, rear lights, and front side marker. I didn't use any resistors or diodes but left the original front turn signal bulbs and just tucked them behind the headlights since I plan on doing JK lenses in the grille.
Unread Today, 06:15 AM   #11
runninbare
When I installed my max-bilt trail taillights and tube fenders with led lights in my 98 TJ I just removed the flasher from under the dash, took the cover off, put a cut in the circuit board, installed the cover and put the flasher back in...no resisters, diodes or anything else. I've heard you may need a diode if you still use your third brake light (which I removed) but I can't confirm that.
runninbare is offline   Reply With Quote Quick reply to this message
Unread Today, 06:17 AM   #12
FtDavisJeep
So I'm replacing my tail lights with LEDs and putting in some new reverse LEDs and license plate LED lights, but I'm not touching anything up front as far as turn/running lights go. I install the new LED EP-26 Flasher and don't need anything extra like the resistors or diodes. But if I replace my front turn single lights with LEDs, then I'd need an in-line diode, resistor on the front turn lights only... Do I have that right festerw?
I Love Shenanigans!
Unread Today, 06:31 AM   #13
festerw
Yes sir you have that correct.
Unread Today, 06:37 AM   #14
FtDavisJeep
Thank you festerw, I appreciate your help. And Thank you to everyone else.
I Love Shenanigans!
Unread Today, 06:47 AM   #15
Loomie
I got this!
Loomie's Avatar
I just installed these...
http://www.maxxima.com/products/prod...T-Back-Up.html
Supper easy to install! I had to add a ground (but that might just be a yj thing) and a EL-12 flasher
they are very bright!
Loomie is offline   Reply With Quote Quick reply to this message
