Who makes softest/smoothest riding lift? - JeepForum.com
post #1 of 9 Old 01-08-2010, 10:26 AM Thread Starter
rkwfxd
OK I do not need a lot of lift 2-3 inches will be enough for my build BUT I COULD go higher.
I don't need a lot of articulation as I do minimal rock crawling.
The vast majority of my 4 wheeling is desert and mountain trails and poorly maintained dirt roads. With that in mind, what lift would provide the smoothest most comfortable ride?
Thanks
rkwfxd is offline
post #2 of 9 Old 01-08-2010, 10:32 AM
ArrizX
Old man Emu as far as I have read.
ArrizX is offline
post #3 of 9 Old 01-08-2010, 10:42 AM
Jrama
I got the BDS 3" basic and the ride is better then stock (with a winch on the front) and you will also get some good flex out of it . It has that unconditional lifetime warrenty. I have had mine on now for about 8 months 4 of which i have had a winch on the front. The ride without the winch is stock maybe a little softer.
What also makes a huge difference on washboard roads is disconnecting the sway bars and yes this kit comes with quick disconnects
Jrama is offline
post #4 of 9 Old 01-08-2010, 10:55 AM
SkylinesSuck
OME, while good, is stiffer than stock by a good bit from what I've felt.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #5 of 9 Old 01-08-2010, 11:06 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
That's all a matter of opinion.Some say this and others say that.I've NEVER rode in a truely smooth riding(by car standards) Jeep.It's the shocks that make or break the ride quality.Also a 2" lift will ride better than a 4" lift on stock short arms.
TheBoogieman is offline
post #6 of 9 Old 01-08-2010, 11:11 AM
shrubeck
My experience has been that it's all about the shocks. My OME springs are super squishy, but with cheap shocks the Jeep rides like crap. My buddy has a short arm 4" procomp lift, but because he has nice shocks his jeep rides much better than mine.
That's what she said.
shrubeck is offline
post #7 of 9 Old 01-08-2010, 11:39 AM
BlackBellamy
BlackBellamy's Avatar
Any long-arm lift. But that's probably too much for your application.
With short-arms, a large percentage of your ride quality will depend on shocks. Look into adjustable shocks like Ranchos so you can dial in the ride that you want.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #8 of 9 Old 01-08-2010, 12:04 PM
Ross
I have Tera 3" coils, some have had problems with them sagging, I haven't and OME shocks. Mine rides smooth for a jeep.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #9 of 9 Old 01-08-2010, 12:16 PM
IslandTJ
This!
The BDS series 2.2 shocks are firmer compared to the OME. I run BDS and I am happy with my ride, much better than stock. But if you want the softest and smoothest quality 2" lift - OME is your product.
I did ride in a OME HD suspension Jeep and the ride was too soft for my preference.
Now Jeeping in Oregon
IslandTJ is offline
Softest Riding Shock for the Rear End jeepsterjc YJ Wrangler Technical Forum 13 03-24-2009 04:00 PM
Who makes the softest 4" Springs BaddAndy TJ Wrangler Technical Forum 33 11-04-2007 09:43 PM
Softest riding 2 inch springs Land Guru 1 TJ Wrangler Technical Forum 5 04-09-2007 07:46 PM
Who makes the softest ride. Bender92YJ YJ Wrangler Technical Forum 16 05-16-2006 09:13 PM
