Who has added an in-line Fuel Pump Check Valve? - JeepForum.com
 3Likes
post #1 of 64 Old 02-01-2009, 10:33 AM Thread Starter
gmiller0737
Who has added a inline fuel pump check valve? where did you get it? I already installed a new Airtex pump (whole assembly) but with my luck the fuel pressure still bleeds off rapidly,I have checked the injectors & every other possibility,Since I bought the new pump off eBay I don't think warranty is possible so I am thinking of just installing a in line check valve
gmiller0737 is offline
post #2 of 64 Old 02-01-2009, 10:34 AM
vtx531
Good question! I plan to do this mod when the weather warms up in a couple months because I have long crank times during a cold start.
vtx531 is offline
post #3 of 64 Old 02-01-2009, 10:40 AM
hunterphfr1
One of the most troublesome, annoying problems I have going right now as well.
hunterphfr1 is offline
post #4 of 64 Old 02-01-2009, 10:47 AM
OldFatGuy
Are you sure pressure is bleeding off through the pump? It could be a leaky injector and a check valve wouldn't do anything to help that.
OldFatGuy is offline
post #5 of 64 Old 02-01-2009, 10:51 AM Thread Starter
gmiller0737
Absolutely positive no injector leak down verified by pulling the fuel rail/injectors, pressure bleeds to zero in 30 seconds or less,No other leaks,New Airtex pump bleeds off faster than the original pump
post #6 of 64 Old 02-01-2009, 12:21 PM
Dogman
Dogman's Avatar
This is the route I was going to go about 1.5 yrs ago. I had the valve and everything. I decided to just get a new fuel pump. I enjoyed quick starts for about 1.5 yrs and guess what?
I'm going the inline route the second time around. I bought mine at a Fluid Connector and IIRC it was about $45.
John 3:17
Dogman is offline
post #7 of 64 Old 02-01-2009, 02:19 PM
sportcoupe
I only put in factory fuel pumps in any vehicle I own for that reason. I do not trust aftermarket fuel pumps. You end up doing the job over and over again even if you have a "lifetime warranty" on the part.
If I was a betting man I'd bet a factory original pump would cure your pressure bleed off problem.
sportcoupe is offline
post #8 of 64 Old 02-01-2009, 03:21 PM Thread Starter
gmiller0737
I agree I wish I would have went that route but I do not have another $300 to throw at this problem so thats why I was wanting to put in a external check valve.
post #9 of 64 Old 02-01-2009, 03:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've seen them in the Summit Racing catalog but it was difficult to find since it's not in the index.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #10 of 64 Old 02-01-2009, 04:00 PM
fasassvalk
tried to pm you
tried to pm you but your 5 messages are full and would not let it go through, let me know and I will forward you some helpful info
fasassvalk is offline
post #11 of 64 Old 02-01-2009, 04:04 PM
BigDWheelin
I'm going to keep an eye on this because I'm running into the same issue with the TJ I just brought home and don't want to have a new fuel pump become part of my regular maintenance.
Let us know how it works out.
BigDWheelin is offline
post #12 of 64 Old 02-01-2009, 05:25 PM Thread Starter
gmiller0737
I emptied my pm box so pm's should go through now Thanks
post #13 of 64 Old 02-01-2009, 05:28 PM
sportcoupe
I can completely understand not wanting to throw more money at it right now, for now you can get brass check valves from McMaster Carr for around $10. You'll have to add a barb pipe fitting to each end to install it in your jeep. Here's the link.
http://www.mcmaster.com/#brass-check-valves/=f37b4
post #14 of 64 Old 02-01-2009, 06:50 PM Thread Starter
gmiller0737
Thank You Kindly! If I don't turn up something here in town tomorrow I will order from them Tuesday
post #15 of 64 Old 02-01-2009, 07:58 PM
sportcoupe
You are welcome. I use McMaster Carr all the time. Their southeast warehouse is in Atlanta so I get ground delivery the next day here in Savannah. I am sure Jacksonville is still in their one day range on ground shipping too.
Fuel pump Check Valve issues... dgi TJ Wrangler Technical Forum 3 12-06-2009 11:14 AM
why is there a check valve on the trans cool line jeffyp06 TJ Wrangler Technical Forum 16 10-27-2008 06:10 PM
Fuel pump problem? Check valve? Waldo1 TJ Wrangler Technical Forum 23 05-17-2008 09:32 PM
Fuel line check valve? Piratejonh TJ Wrangler Technical Forum 2 10-05-2006 11:02 AM
Fuel Line Specs/Questions - Installing Check Valve Dogman TJ Wrangler Technical Forum 11 06-05-2006 08:10 AM
