White Smoke Above Dash Drivers Side - JeepForum.com
 2Likes
post #1 of 18 Old 06-17-2017, 05:03 PM Thread Starter
Cjs89YJ
Hi All,
2003 TJ, 4.0, 5 speed
So this problem has happened to me about 4 times now. Basically after driving somewhere occasionally I will notice some white smoke coming out from between the dashboard and windshield frame just above the drivers side vent.
1) My first thought was that I was burning the Clutch because it was after I had been sitting in some heavy traffic on a hill. But this was just 1/4 times, the other 3 times were normal driving conditions although a lot of stop and go.
2) Each time I believe I had vent knob on one of the AC settings, my AC however doesnt work I just leave the knob usually in the recycle position. After searching the forums, I saw some people suggest it was a freon leak, but I never got any odor.
About my AC, it didnt work when I bought the jeep so I decided to get a mechanic to top up the freon to see if I had a leak, but he said the system was already charged.From there I didn't really bother to look much further into the AC problem.
My real question is this something I should be worried about? I regularly check all the jeeps fluids and the jeep never overheats so I'm wondering what this occasional smoke is.
Any help is much appreciated.
cheers
89 YJ 4.2 5speed - 1" Spacers / 31" MT
93 YJ 4.0 Auto
03 TJ 4.0 5speed - 2.5" lift/ 31" AT
Last edited by Cjs89YJ; 06-17-2017 at 05:03 PM. Reason: forgot to put the jeep details
Cjs89YJ is offline
post #2 of 18 Old 06-17-2017, 05:44 PM
biffgnar
biffgnar's Avatar
Are you sure its smoke and not steam? Was it humid and rainy when it did it?
On another note, your ac has R134 in it not freon and I think it is relatively odorless.
Romney in 2020!
biffgnar is online now
post #3 of 18 Old 06-17-2017, 07:11 PM Thread Starter
Cjs89YJ
Ok that makes a lot more sense, it was a somewhat humid day today because it had just finished raining. And I'm cant 100% remember but i'd say the earlier times might have been humid as well. And my mistake about the freon/r134 mix up that would also explain why i didn't smell anything.
Its supposed to rainy/humid out again tommorrow so I will look more closely but it might be steam, its just the amount of steam might have misled me to call it smoke. In any case would this steam/smoke be a result of whatever the broken part is on my ac?
93 YJ 4.0 Auto
Cjs89YJ is offline
post #4 of 18 Old 06-17-2017, 07:27 PM
biffgnar
biffgnar's Avatar
An a damp humid day a perfectly functioning hvac system can blow steam out the vents.
Romney in 2020!
post #5 of 18 Old 06-17-2017, 07:45 PM Thread Starter
Cjs89YJ
Only thing that worried me was that it wasnt out of the vents, but above them from the dash. I understand what you mean it most likely is steam and Im just worrying over nothing hahahaha
Thanks for the reply!
93 YJ 4.0 Auto
Cjs89YJ is offline
post #6 of 18 Old 06-17-2017, 08:22 PM
JEK3
JEK3's Avatar
Could it be possible that your A/C actually works, but something is broken in the ducting so it never actually gets to the vents?
JEK3 is online now
post #7 of 18 Old 06-17-2017, 09:21 PM Thread Starter
Cjs89YJ
The vents themselves do blow air just not "cold". Given that the ac system is charged anything could be possible as to why it doesn't work.
93 YJ 4.0 Auto
Cjs89YJ is offline
post #8 of 18 Old 06-18-2017, 05:12 PM
Dodger60
Keep an eye on your coolant level as the first sign of a failing heater core can be just such a white steam coming from the dash..it would smell a bit like antifreeze though so likely it isn't that..just be on the lookout...
Sent from my Nexus 5 using Tapatalk
prjohnson likes this.
Dodger60 is offline
post #9 of 18 Old 06-19-2017, 04:39 PM Thread Starter
Cjs89YJ
OK. So today I went to work and it wasn't a humid day and I had the function knob turned to off. However there was still a bit of smoke, and I say smoke because I looked closer at it and it definitely was not steam. I also noticed my reverse lights had stopped working again. Then this idea sort of clicked into my head. Each time i saw this smoke was after I had finished driving and reversed into my parking spot (i always reverse in because other wise its tough in the morning). Now my reverse light and switch was replaced at the start of May, the reason it stopped working was unknown. Now less than 2 months later my reverse lights dont work and this smoke happens after reversing in. Could it be that something is shorting causing this smoke and my reverse lights to have blown again?
Dodger60 likes this.
93 YJ 4.0 Auto
Cjs89YJ is offline
post #10 of 18 Old 06-19-2017, 04:46 PM
Dodger60
That does sound like a possibility..
Dodger60 is offline
post #11 of 18 Old 06-19-2017, 04:54 PM
Jeep_Couple
2017 JK Wrangler
I wouldnt worry to much about the AC but my opinon on the ac is you might have a clogged line and that is why he is saying it is charged becuase the line is clogged. I had this issue with one of my cars before and I just replaced all the hoses. That might work. I was having an issue with my clutch in my jeep and started smelling what seemed like something burnt and I thought it was the clutch but it was the car next to me. I have to remember to shift at 3000 rmps or I smell that.
Jeep_Couple is offline
post #12 of 18 Old 06-19-2017, 05:00 PM
Raist11
Raist11's Avatar
Does it smell? What does it smell like? What was wrong with the switch they replaced? Was it burned/melted? White smoke coming from dash is not a good thing.
Current: '00 TJ Sport
Past: '98 TJ Sport - lots of aftermarket
Raist11 is online now
post #13 of 18 Old 06-19-2017, 05:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is the carpeting damp under the passenger-side footwell? Maybe your heater core has sprung a leak, they do that.
Jerry Bransford is online now
post #14 of 18 Old 06-19-2017, 07:44 PM Thread Starter
Cjs89YJ
Right now theres too many possibilities, I wish it was just steam
I agree the AC is not a huge worry of mine, but when I get home in September I will have some time to try replacing hoses and such. As for the clutch I agree, one rough day on a hill would not show effects this long. Nor did it smell like clutch that day or this.
Thats the thing, I didnt really get a burning smell just the smoke. And by smoke I dont want to exagerate it, its not a huge amount of smoke but still enough to be noticeable. Again I will try pick out anything I smell on my way tomorrow. As for the old switch, I was told it was burnt out and once it was replaced the reverse lights started working. And I agree the sooner I find out what this smoke is and stop it the better.
I checked the passenger footwell, because my inital search led me to a thread about heater core / ac evap issues. This however does not seem to be the case the carpet is not damp nor does the foot well show any signs of water when I lifted it up.
My plan tomorrow is to take it to a mechanic before work because sadly until September when I go home the apartment lifestyle means the jeep stays parked 3 floors underground and I cant do any work on it while its there.
93 YJ 4.0 Auto
Cjs89YJ is offline
post #15 of 18 Old 06-20-2017, 05:51 AM Thread Starter
Cjs89YJ
OK took it to the mechanic just now. Today is a rainy humid day. Purposely reversed like 5 times to try and replicate the problem. Also had the knob set to recirculate. AND nothing!!!! Mechanic was no help because he said unless the problems visible he cant really diagnose which I agree completely. So here I am back to chasing a ghost....
93 YJ 4.0 Auto
Cjs89YJ is offline
