whistleing - JeepForum.com
post #1 of 7 Old 11-21-2013, 02:42 PM Thread Starter
dawnlauffer
whistleing
My 98 wrangler has a whistle that is driving me NUTZ ..Can anyone tell me is it the air intake the trottle plate or wtf? when I am driving ..it seems like when the gas pedal is in a certain spot it lets up the whistle.but it is so loud people stare! I have replaced the big main belt on it! could it be the air intake>? I don't enjoy driving "BIG RED" no more due to this whistle! Please help..oh also had the throttle plate cleaned up..and getting a new air filter tomorrow and have a new throttle sensor to put on hopeing it will help
dawnlauffer is offline
post #2 of 7 Old 11-21-2013, 03:58 PM
BadApple1403
Stock or aftermarket intake? The PO put an after market on mine it does the same as yours.. sometimes just twisting the filter will stop the noise didn't work for mine but has worked on other vehicles
BadApple1403 is offline
post #3 of 7 Old 11-21-2013, 04:02 PM
JBTJ
I don't suppose it has a throttle body spacer installed does it?
JBTJ is offline
post #4 of 7 Old 11-21-2013, 04:40 PM
merkchop
All stock or modified? (TB spacer, cold air, etc). Picture if you have it. My 98 had the spacer and cold air (sort of) and it would whistle when giving it gas and at certain throttle positions.
Now for worse case, oneof my 01's had an annoying whistle, all was stock and it ended up being a bad intake manifold gasket.
Hopefully that will help some.
merkchop is offline
post #5 of 7 Old 11-21-2013, 06:00 PM Thread Starter
dawnlauffer
thanks people! me and my man are racking our brains trying to figure it out! will get back to all soon ..my man is a coal miner and don't hae much time to look at it....plus my daughter drives it to work and back so I don't hae it much any more to look at it as much as I would like...but every little bit helps!!!!!
post #6 of 7 Old 11-21-2013, 06:01 PM Thread Starter
dawnlauffer
I do not know if it has bottle throttle spacer will have to ask my man if it does and get back to you
post #7 of 7 Old 11-21-2013, 09:04 PM
zeke8
tighten up the intake manifold bolts. mine came loose slightly and it would whistle for the first 1-5 minutes depending on engine temperature. The colder it was outside the longer it would take for the tolerance between the head and intake to expand and seal the leak. I believe they are 14mm bolts, if the noise is continuous spray intake cleaner to find the leak, maybe the intake has a crack.
zeke8 is offline
