Whirring, squeaking noise? HELP! - JeepForum.com
post #1 of 5 Old 03-21-2006, 04:15 PM Thread Starter
nman642000
I've noticed lately that, when I start my 99 4.0 Jeep (5-sp) that there is a loud whirring/squeaking sound. After I begin to drive, the sound occurs at and over around 1200 rpm. It's not consistent below that, if I have the AC on, it'll quit if I turn it off, but will start to make it again, just not as sustained. This started last week or so with just a small noise when I started the vehicle, then it quit soon after, then it would make it when I released the clutch to move, now it does it when I'm driving down the road. After a 1-2.5 minutes, the sound will cease, but will start again when I start the Jeep up.
Any ideas before I take it to my mechanic? Thanks!
Cory
ME:
-1999 TJ
-4.0 6-cyl
-5 speed
-Pretty much stock (But workin' on changing that!)
nman642000 is offline
post #2 of 5 Old 03-21-2006, 04:17 PM
vonmendel
vonmendel's Avatar
Check the belt, check the tensioner, check the alternator. Sounds like just a belt though.
97 TJ
LIFT: Pro Comp 4 inch stage 2
MEATS: 33" TSL on black series 97 P/C's
ARMOR: Scrapmetal Customs front 3rd Kage and bumper
LUNG: White River Prototype Snorkel
TUMMY: in the worx
RECOVERY: a good collection of straps!
vonmendel is offline
post #3 of 5 Old 03-21-2006, 04:25 PM Thread Starter
nman642000
Forgot to mention that I recently replaced the serpentine belt. checked tension and it's good; and it's routed properly.
Do these vehicles with the serpentine belts have timing belts anymore?
Or is the the serpentine the only belt on the car?
ME:
-1999 TJ
-4.0 6-cyl
-5 speed
post #4 of 5 Old 03-21-2006, 05:22 PM
abnormal
Platinum Member
abnormal's Avatar
Does it do it only when you are moving or when the Jeep is parked with engine running? If its only making the sound when you are rolling then it sounds like a case of angry sparrows(front driveshaft needs to be lubed). If its doing it when its parked then it sounds like the belt. To find out you can take some tooth paste(the paste, not the gel) and put some on the contact side of your belt and run it to see if it stopped. Some people like to use the belt dressing but if you use too much of it or for too long you could make the sound even worse. Good luck!
abnormal is offline
post #5 of 5 Old 03-23-2006, 04:25 PM
vonmendel
vonmendel's Avatar
no timing belt just a chain. Scuba had a good point about the front driveshaft though. Timing Belts usually don't squeak even if you had one. Let us know what it was for future reference. Good Luck man.
97 TJ
TUMMY: in the worx
Deceleration whirring noise JeepRubi04 TJ Wrangler Technical Forum 10 12-09-2009 04:46 PM
Whirring noise behind firewall jeepwildcat TJ Wrangler Technical Forum 3 10-17-2009 07:45 PM
Whirring/Squeaking/Grinding Clutch Rick5150 TJ Wrangler Technical Forum 4 09-23-2009 03:58 PM
Loud whirring noise in 4WD! EABiker YJ Wrangler Technical Forum 1 01-08-2007 07:48 AM
Whirring Noise woodb TJ Wrangler Technical Forum 11 09-24-2006 10:26 PM
