whine from transmission area 1st & 2nd gear - JeepForum.com
post #1 of 5 Old 06-18-2009, 06:02 PM Thread Starter
rbluhm
I have a 98 Wrangler 2.5L w/ 5sp manual. I am getting a loud whine when starting out in 1st & 2nd gear it seams to do it more when weather is warm. It is intermittent though, I can drive and it does it for half a day then the other half it doesn't which makes hard for my dealership to figure out. It almosts sounds like the 4wd is engaged making more sound and then it will then go back to 2 wd making the sound go away. Don't know if this has anything to do with it but this winter when the temps were below 0 I had a hard time shifting through the gears so I had my dealership put in synthetic fluid in the trans and this helped the problem alot. Could this contibute to the problem or does anyone any othe advice or ideas?
rbluhm is offline
post #2 of 5 Old 06-23-2009, 07:11 AM Thread Starter
rbluhm
air conditioning
doesn't do it with air conditioning turned off
rbluhm is offline
post #3 of 5 Old 06-23-2009, 08:21 AM
alexr40
are you sure it doesnt come from the air compressor?
mine does a "shshshshsshs shhhhhhhhhh" from the air compressor on 1st/2nd when I floor it..
seems like the bearings are going south
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #4 of 5 Old 06-23-2009, 12:58 PM Thread Starter
rbluhm
Maybe, How long has yours been making the noise? Just wondering if I need fork out the cash to fix it right away or not if it is that. The noise isn't unbearable.
rbluhm is offline
post #5 of 5 Old 06-23-2009, 01:00 PM
alexr40
about 3 or 4 months
alexr40 is offline
Transmission whine? 93jeepsport TJ Wrangler Technical Forum 3 10-17-2007 10:35 AM
TJ Transmission whine Wild Bill TJ Wrangler Technical Forum 2 04-09-2007 10:33 AM
Transmission whine blazin YJ Wrangler Technical Forum 16 10-05-2006 06:30 AM
Transmission Whine jo88gta YJ Wrangler Technical Forum 7 03-05-2004 04:21 PM
Transmission, gear, whine doctorfireant YJ Wrangler Technical Forum 10 10-23-2001 08:54 AM
