Where's the other 2 speakers ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Where's the other 2 speakers ?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-14-2006, 10:55 AM   #1
jtstj
Location: Beautiful Colorado Springs, Colorado, Colorado
My new Unlimited came with the "7 speaker " sound system. I can only find 5 speakers including the SubWoofer. Does anyone else know where the other 2 speakers are ? Are they tweeters, built into the SubWoofer ?
jtstj is offline   Reply With Quote Quick reply to this message
Unread 03-14-2006, 10:58 AM   #2
06slvrrubi
Lovin' Life
06slvrrubi's Avatar
There are two in the overhead sound "pods", the sub in the center console, and there are two speakers, and two tweeters in the dash. So there are actually four speakers in the dash, two overhead, and the sub = 7 speakers total.
Jeepless
2007 Avalanche LTZ
06slvrrubi is offline   Reply With Quote Quick reply to this message
Unread 03-14-2006, 10:59 AM   #3
yankeejeeper02
speakers
you have 2 in the sound pods, 1 sub, and 4 in the dash...(the 4 in the dash are two mids and two tweeders. there all located in the same spot in the dash. hope this helps
yankeejeeper02 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2006, 10:59 AM   #4
TJay2004
The tweeters are built into the dash speakers. The 7 speaker option is kind of questionable. If you look at them they almost qualify as 1 speaker.
2004 Red TJ Sport
4.0L, 3.73, and Dana 44 Rear
2" Suspension lift
3/4" Daystar Front Coil Spacers(made it level)
31"x10.5" Dick Cepek FC II's on MT Classic II Wheels
Sirius Satellite Radio
Olympic sliders
Rubicon fender flares
TKH Rear Bumper
More to come....of course...
TJay2004 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2006, 05:52 PM   #5
jbpdog
if you ask me, might as well not come with speakers. the stockers are so crappy. You can actually poke a hole in them if you blow on the cone too hard. When you replace them with aftermarket ones, the stockers will make good frisbees.
jbpdog is offline   Reply With Quote Quick reply to this message
Unread 03-14-2006, 06:26 PM   #6
BlueFlame
Tip on replacing the speakers: If you are going to stick with the stock head unit, look for speakers with high SPL numbers, like 91 or higher. I've put Pioneers for example (which are very affordable if you shop around) in a couple of cars now and they sound great (for themoney)! My buddy put $400 worth of high quality speakers in his TJ and it sounds no better than stock - they need power, and they need volume to sound good, at normal volumes they are weak. This is made even worse by those silly plastic pods on the roll bar...
BlueFlame is offline   Reply With Quote Quick reply to this message
