Where's the freon going? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Where's the freon going?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-25-2010, 06:45 PM   #1
Daddyhog
I have a 2000 TJ which has developed a freon leak. I can charge up but within two days it's gone. I have put the UV dye in but cannot see any leaks on the compressor or other fittings. Does anyone have suggestions what or where to look for the leak?
Daddyhog is offline   Reply With Quote Quick reply to this message
Unread 07-25-2010, 06:51 PM   #2
chadsmeltzer
Get some UV goggles or a sniffer. If it's leaking that much in two days, it must be a pretty good size leak. Did you follow it all the way back to the evaporator?
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline   Reply With Quote Quick reply to this message
Unread 07-25-2010, 06:56 PM   #3
Daddyhog
I"ve checked everywhere in the engine compartment although I really can't see the condenser lines wherte they attach to the condenser. Is there somewhere in the inside I need to check? How can you check the evaporator?
Unread 07-25-2010, 08:01 PM   #4
MM1Jeeper
Had a bad leak on my son's cavalier. It was from the compressor seals. Took a while to find, but that is where it was from. Good luck.
Jay
4.5" RE SF, 33x10.5 Mickey Baja Claws, Shrockworks Rockers,Skidrow Engine/Tranny skid, Warn 9500ti, Currie HD steering
MM1Jeeper is offline   Reply With Quote Quick reply to this message
Unread 07-25-2010, 09:11 PM   #5
larjeep
It's the evap. That is very common leak for tj. And it's
in the dash. Pain in the as. Get a good sealer about 30bucks not the cheap **** and put it in. It will work on it.
DO IT ALL, AND THAN SOME!
larjeep is offline   Reply With Quote Quick reply to this message
freon , leak , ac , a/c , tj , wrangler
