Where's the freon going? - JeepForum.com
post #1 of 5 Old 07-25-2010, 06:45 PM Thread Starter
Daddyhog
I have a 2000 TJ which has developed a freon leak. I can charge up but within two days it's gone. I have put the UV dye in but cannot see any leaks on the compressor or other fittings. Does anyone have suggestions what or where to look for the leak?
Daddyhog is offline
post #2 of 5 Old 07-25-2010, 06:51 PM
chadsmeltzer
chadsmeltzer's Avatar
Get some UV goggles or a sniffer. If it's leaking that much in two days, it must be a pretty good size leak. Did you follow it all the way back to the evaporator?
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #3 of 5 Old 07-25-2010, 06:56 PM Thread Starter
Daddyhog
I"ve checked everywhere in the engine compartment although I really can't see the condenser lines wherte they attach to the condenser. Is there somewhere in the inside I need to check? How can you check the evaporator?
Daddyhog is offline
post #4 of 5 Old 07-25-2010, 08:01 PM
MM1Jeeper
Had a bad leak on my son's cavalier. It was from the compressor seals. Took a while to find, but that is where it was from. Good luck.
Jay
4.5" RE SF, 33x10.5 Mickey Baja Claws, Shrockworks Rockers,Skidrow Engine/Tranny skid, Warn 9500ti, Currie HD steering
MM1Jeeper is offline
post #5 of 5 Old 07-25-2010, 09:11 PM
larjeep
It's the evap. That is very common leak for tj. And it's
in the dash. Pain in the as. Get a good sealer about 30bucks not the cheap **** and put it in. It will work on it.
DO IT ALL, AND THAN SOME!
larjeep is offline
freon , leak , ac , a/c , tj , wrangler
A/C freon Scotti TJ Wrangler Technical Forum 11 07-10-2009 10:52 PM
freon capacity 88wagon TJ Wrangler Technical Forum 9 09-03-2008 10:27 PM
How much freon? JBWrangler2000 TJ Wrangler Technical Forum 2 08-08-2007 07:28 PM
A\C needs freon red 98 TJ Wrangler Technical Forum 4 06-27-2006 08:31 AM
How much Freon? mgaspard TJ Wrangler Technical Forum 4 06-06-2006 11:13 PM
