Quantcast where to mount air tank in jeep? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > where to mount air tank in jeep?
Old 02-05-2007, 07:48 AM   #1
drummerwookie
first off, not sure if this belonged here or in GD, but figured it fit better here so move it if you like
in a couple weeks, im going to get a fairly cheap air compressor for the jeep, to fill tires up with after wheeling, and to use impact wrenches when needed, and i was just wondering, where is the best place to mount the air tank? should i mount it in the back, and feed enough line up to the compressor, or mount it all under the hood?...any suggestions would be helpfull
1993 YJ 4.0, 5-spd, 31x10.5 MTRs wrapped around AR Outlaw II's, tabor 9k winch, 4 inch trailmaster lift
gone, but never forgotten: 2006 rubicon, 1998 ZJ, 1995 YJ 4.0
metalhead jeep club #4
drummerwookie is offline   Reply With Quote
Old 02-05-2007, 07:54 AM   #2
JeepNazi101
this is what i did, old tank and cheap compressor
"Professional Driver on a Closed Course"
http://offroadiowa.com/
http://www.4x4syndicate.com/
i has a kool buggy
JeepNazi101 is offline   Reply With Quote
Old 02-05-2007, 08:16 AM   #3
BoKnows
A lot of people mount it under the jeep by the driveshaft opposite the muffler and run lines along frame rail from there
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
WWW.MILITARYJEEPERS.COM
WWW.WHEELERSFORTHEWOUNDED.ORG
BoKnows is offline   Reply With Quote
Old 02-05-2007, 08:20 AM   #4
drummerwookie
with that set up, are you able to use an impact wrench much, or does work for a short while, then have to wait for it to fill back up, then it works for another 5 min?..or is it good to use for jobs all over the jeep without it having to fill up with air to often?
just curious, bc my boss was telling me, with the compressor im looking at, its the MV50, only a 70 dollor compressor, but he said that it would work long enough to take a couple lug nuts off, then have to wait a couple minutes, then take 2 more off, so on and so forth...bc, i want a set up that i can use to actually work on my jeep, as well as fill the tires up after trail riding
that looks like a good set up by the way, thanx for the picture
Old 02-05-2007, 08:37 AM   #5
BoKnows
Look at the air tools your using and and the )SCFM) square cubic feet per minute rate of consumption. My impact wrench likes air like a sailor likes his rum. Bottom line, your boss is right you'll only be able to use it sparingly then have to wait for your compressor to recycle. Still a great thing to have and would be best for filling tires.
Of course, this is all second hand but I am sure there are plenty of guys on here who runa system like this.
1997 TJ White
Old 02-05-2007, 08:48 AM   #6
mjm
I mounted mine under the tub. It is located behind the transfer case skid on the drivers side. I have seen a Kilby tank mounted under the hood near and parallel to the firewall. It works very well for this guy, who has a dedicated trail Jeep.
mjm is offline   Reply With Quote
Old 02-05-2007, 08:48 AM   #7
drummerwookie
thanx for the info jason. i dont know much about air compressors or how they work with tools. i just know they can be VERY handy at times..lol....hell, even if i cant use it much for a tool, i still got all my other great tools to use..all i really need it for is airing my tires back up so i dont have to go searching for an air pump somewhere
Old 02-05-2007, 08:50 AM   #8
drummerwookie
here is the air compressor that im looking at...like i said, its cheap, but as long as it will air up tires, i dont care how long it takes, then itll work for me
http://www.4wd.com/Jeep-Parts-Tops-and-Accessories/PARTMV50.aspx
Old 02-05-2007, 09:51 AM   #9
5artist5
5artist5's Avatar
1972 CJ5
Wow so that's almost a half hour to air back up? You are a ver y patient person.
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline   Reply With Quote
Old 02-05-2007, 10:00 AM   #10
drummerwookie
lol..ah, it doesnt bother me...when im inside, doing some kind of indoor activity, i am a very impatient person...lol..i get agrivated easily...but, outside, enjoying the outdoors, im a very patient person
Old 02-05-2007, 10:05 AM   #11
JeepNazi101
I have an electric inpact that i use while on the trail, this is only for airing up......and does not work very well. It is a Harbor Freight compressor. Cheap and it works but not the best.
i has a kool buggy
Old 02-05-2007, 10:22 AM   #12
RnEmOvr
Never Forget
RnEmOvr's Avatar
how long does it take per tire with HF compressor only, say tank was empty
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 02-05-2007, 10:25 AM   #13
RockRunner85
Heres how I mounted mine. Got the tank off ebay.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 02-05-2007, 10:27 AM   #14
RnEmOvr
Never Forget
RnEmOvr's Avatar
rockrunner whats the piece clamped to frame?
www.cityprofile.com
Old 02-05-2007, 11:32 AM   #15
RockRunner85
That hold the tank. I got some steal and made a mount out of it. You could just bolt it to the tub, but I plan to go LA in the future and wasn't sure where you put it where it wouldn't interfere. So I did that for now.
The Reptile File
Glock Forum
