where to find auto transmission gear ratios - JeepForum.com
post #1 of 10 Old 02-28-2008, 10:32 PM Thread Starter
snakehunter
improving crawl ratio
Where can I find the gear ratios for my 2000 auto transmission and the transfer case low range?
I'm trying to understand how to calculate the crawl ratio
my understanding is craw ratio = transmission 1st gear ratio X transfer case low range X 4.56 (my axle ratio)
Thanks.
2000 Sahara RE 4.5, Alloy USA front Axles (D30) w/Aussie locker, Superior Super 35, 4.56 gears, OME Shocks, Centric Front Discs w/EBC Yellow pads, AtoZ Fab Rocker Guards,Goodyear MT/R 33x12.5x15 on 15x8 Rock Crawler 51's, other minor stuff...
/ | [____],
1---L-OlllllllO-
()_)()_)----)_) White Jeep Club Member #111
snakehunter is offline
post #2 of 10 Old 02-28-2008, 10:42 PM
NakedJeeper
NakedJeeper's Avatar
Crawl Ratio Formula : Transmission Ration * Transfer Case Ratio * Axle Ration = Crawl Ratio
There are a bunch of gear ratio calculators on the net. Google is your friend.
http://www.nakedjeep.com/Knowledge/Math/njRatios.html
http://www.nakedjeep.com/Knowledge/M...ulators02.html
NakedJeeper is offline
post #3 of 10 Old 02-28-2008, 11:06 PM Thread Starter
snakehunter
Did a google search for the calculation but didn't find out where I could find the actual gear ratios.... Thanks.
Now that I know them I'm not impressed.. I'm at about 28 without any changes (3.73 axle ratio) and only get to 50 regearing to 4.56 and adding a teralow.
Is there a way to get real low without the atlas?
It didn't seem to add that much going to 4.88 and it's my daily driver anyway.
Or, should I not pay attention to my toyota friends who boast of more than a 100 crawl ratio?
/ | [____],
1---L-OlllllllO-
post #4 of 10 Old 02-29-2008, 06:27 AM
Pillswoj
Try here, there should be a listing for your Tranny.
http://www.grimmjeeper.com/gears.html
Regards,
Jeff
Pillswoj is offline
post #5 of 10 Old 02-29-2008, 09:02 AM
NakedJeeper
There is a challenge getting a daily driver to crawl low and still hit freeway speeds. For a good balance you can get a Stak or TeraLow 4:1 or other transfer case option to get you a lower gear in 4-low - when you really need lower gears. That would not negatively affect freeway speed and power.
If you just lower the axle gears by going to 4:88s, then your lower at all speeds. You really need to gear the axles to match the tire size so you have good power in 2 wheel drive, too.
Just my humble opinion
post #6 of 10 Old 02-29-2008, 09:05 AM
jcssurf
You're forgetting that with your auto the torque converter pretty much add's a 3:1 gear ratio. So triple whatever you calculated.
But why do the numbers matter? Go by what feels right to you on the trail. I think with your 33's, 3speed, and 3.73's you have a perfect DD combo. But if you want a bit more offroad, do 4.10's.
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline
post #7 of 10 Old 02-29-2008, 10:57 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by jcssurf View Post
You're forgetting that with your auto the torque converter pretty much add's a 3:1 gear ratio. So triple whatever you calculated...
jcsurf is right on, you have forgotten about your torque converter.
You really cannot calculate an accurate crawl ratio. When your Yota buddies with manuals are bragging about crawl ratios in the 100's just tell them that your's is nearly infinite.
For future reference, the "Stock TJ Specifications" thread at the top of the forum has all of the ratios. Here's a link:
http://www.jeepforum.com/forum/f9/stock-tj-specifications-452871/
Wheelin98TJ is offline
post #8 of 10 Old 02-29-2008, 04:11 PM Thread Starter
snakehunter
http://www.jeepforum.com/forum/showthread.php?t=452871
spent time studying how it works and adding the torque converter comment means I've got more to learn.
Why (sound like my kids) or how does it add to the ratio?
Why the comment about it being infinite? Can you explain that as well?
Or, just point me to someplace reliable to read something on the subject.
thanks for the input.
/ | [____],
1---L-OlllllllO-
post #9 of 10 Old 03-01-2008, 06:19 AM
Wheelin98TJ
JEEP FREAK
The reason your crawl ratio is nearly infinite is because of the torque multiplication effect the torque converter has.
Here's a pretty good link that explains how the torque converter works:
http://auto.howstuffworks.com/torque-converter.htm
post #10 of 10 Old 03-02-2008, 10:48 AM Thread Starter
snakehunter
Thanks for the link - lots of good stuff....
Thanks everybody else as well...
/ | [____],
1---L-OlllllllO-
Auto transmission slams into gear GERD JK Wrangler Technical Forum 8 12-02-2009 09:05 PM
Transmission ratios for manual and auto? TNez JK Wrangler Technical Forum 26 11-20-2009 06:37 PM
auto transmission no 2nd or 3rd gear. tjhavasu TJ Wrangler Technical Forum 5 02-25-2009 11:54 PM
Manual transmission gear ratios Hook67 JK Wrangler Technical Forum 4 04-24-2008 08:15 AM
Transmission gear ratios N_P TJ Wrangler Technical Forum 8 04-02-2007 07:57 PM
