Where does the fog light switch go? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Where does the fog light switch go?
TJ Dana 60 - BOLT IN REARRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge Bushings
Unread 11-22-2005, 11:11 PM   #1
msrynear
Hello - I have an '03 Wrangler X - no hard top or fog lights so I have three blank spots where the defrost, wiper, and fog light switches go. I am installing factory fog lights next week - which slot does the fog light switch normally go in? Have I said the phrase 'fog light' enough times in this post? Thanks!
'03 Wrangler X
4.0L, 5 spd manual
2" lift, 31x10.5x15's
'97 Cherokee Sport (stock)
4.0L, Auto
(sold 8/18/06)
msrynear is offline   Reply With Quote
Unread 11-22-2005, 11:13 PM   #2
Rocky529
Jeep
Rocky529's Avatar
I believe it is on '03+ Wranglers, but anyways the fog light switch was moved to the turn signal stalk. You pull it out towards the door to activate the fog lights. The switches in the center stack (below the hvac controls) is where the defroster, rear wiper and axle lock switches come stock. You could wire it up there, but if you want a factory appearance, you will have to buy a new turn signal stalk. From what I hear, it is a pita to wire in.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 11-22-2005, 11:28 PM   #3
AjRagno
http://www.jeepsareus.com/Merchant2/...Code=Wrangler7
AjRagno is offline   Reply With Quote
Unread 11-23-2005, 06:38 AM   #4
jeffjeep1
jeffjeep1's Avatar
As posted above, the fog light switch moved to the turn signal stalk, but in 2001. If you bought a Jeep accesoriy kit it should have the correct switch in it. In 2003 the dash panel changed to hold 4 switches left to right, Rear Defog, Rear Wipe/Wash, O/D off (if automatic), and Axle lock (if Rubicon).
If you are doing your own adapting with a 2000 and earlier switch, I suspect the switch will fit into one of two right hand holes. It is fairly easy to remove the switch panel, but be sure you have all screws out. It doesn't have to be forced to remove it.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline   Reply With Quote
Unread 11-23-2005, 02:37 PM   #5
sparkeep
As stated above, the factory fog is on the steering wheel. But the factory switch fits into any of the slots in the dash.
I put a foglight switch in the 3rd spot because I don't have the automatic tranny and will therefore never need the overdrive switch.
Cheers
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline   Reply With Quote
