Quantcast where do you put your disconnected stock sway bars? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > where do you put your disconnected stock sway bars?
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 01-18-2010, 08:32 PM   #1
jeepgunner12
Im going to try to build a shovel holder for my roof rack tomorrow but if i have some spare time i want to see for myself how much flex i can get out of my jeep. I have beefed up sway bar links but they are still pretty much stock size and function like stock ones do. It seems to me that i run the risk of crunching somthing if i just leave them hanging there while i go crawling up a log. I will of course go very slow but are there any ways i can be sure these links are out of the way without taking them all the way off? (i only plan on removing the bottom torx bolt)
Just for fun, any ideas on how high a wrangler with stock tires and a 2.5 suspention kit can get a tire up?
GREEN JEEP CLUB #385
PM me if you have an old hilift and/or a 31x10.5 R15 youd like to trade or sell, im in the market for a jack and a trailspare. Cheers!
jeepgunner12 is offline   Reply With Quote
Old 01-18-2010, 08:47 PM   #2
matthewh_1
Torrent Offroad
matthewh_1's Avatar
I have the JKS quicker disconnects, and they come with a pin that you attach to your frame, and you just fold them up and put them on the pin and they get held in place there. Kind of hard to explain.
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline   Reply With Quote
Old 01-18-2010, 09:05 PM   #3
Thexonexkid
Thexonexkid's Avatar
1986 XJ Cherokee
JKS Discos
I have JKS quick discos on the front. Here is a pic of what I have while the quick discos are up on the sway bar is not connected. You just pull out the pin on the bottum quick disco and move it into the upright position and lock it into the position as shown below.
In the picture attached the blue circle is the quick disco in the upright and locked position and the blue line is where it would be when it is connected to the spring.
The quick disco will stay connected to the sway bar at all times just not connected to the spring.
Make sure you remove these when you are driving on anything not the road I have inverted them very very easily.
84 CJ7 Rebuild:
http://www.jeepforum.com/forum/f8/cj7-re-build-1299733/
Thexonexkid is offline   Reply With Quote
Old 01-18-2010, 09:06 PM   #4
Thexonexkid
1986 XJ Cherokee
sorry its sorta small the bar with the sticker on it that little white sticker is the quick disco inside the blue circle.
84 CJ7 Rebuild:
Old 01-18-2010, 09:14 PM   #5
J03_TJ
J03_TJ's Avatar
Here's a close up of my JKS disco's on the storage pin position. I need to move the pins a little more forward so they clear the tire better when stuffed. FYI, I cannot remember the last time I actually put them back on the axle even though it's my DD.
J03_TJ is online now   Reply With Quote
Old 01-18-2010, 09:22 PM   #6
nuclearstrife
Thanks guys for the pictures. Now I have a better idea for where to put my stow pins.
J03_TJ how much further do you need to put them so they wont rub? And if you could tell me a distance from something so I can get the right spot.
Thanks
nuclearstrife is offline   Reply With Quote
Old 01-18-2010, 10:25 PM   #7
J03_TJ
J03_TJ's Avatar
Thanks
I just measured and the pins are now at just about 3" behind the slotted hole shown in the pic. Just "ball parking it" I am going to re-mount them about 2" forward from where they are now, so about an inch behind the slotted hole. From what I can tell the tires should not hit the pin area with this change, and if they do still rub it will be on the black tube portion of the disconnect. I don't think they will hit though since I have two washers on each steering stop. As is the driver side rubs on the storage pin keeper pin and keep busting them off.
Also, mount one side pin and then put that side's link in place and go to the other side and using the other link's bushing mark where you need the second side mounted.
Hope this helps.
Old 01-18-2010, 10:52 PM   #8
MikeBK
MikeBK's Avatar
Sounds to me like you don't want to buy swaybar disco's you just want to disconect what you have and go play around tomorrow. I don't have the fancy discos yet so I just keep some heavy zip ties in the Jeep, have not failed me yet,
Consider Obama the lesson many in this country need to learn, the rest of us just have to pay for it!http://obamaclock.org/
MikeBK is offline   Reply With Quote
Old 01-19-2010, 09:40 AM   #9
97tjconan
Here is a pic of JKS Disco,s
97tjconan is offline   Reply With Quote
Old 01-19-2010, 10:09 AM   #10
Hesher420
!!! SLAYER !!!
Hesher420's Avatar
1.Find a hole
2. Drive in it
FOR SALE*NIB*TJ CHOME GRILL OVERLAYCLICK HERE
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Old 01-19-2010, 10:12 AM   #11
Warren
I have home-made disconnects (hitch pins etc).
I push the sway bar up and lay the rods on top of the shock towers - They stay put even through the rough stuff.
-- Warren in San Diego
Warren is offline   Reply With Quote
Old 01-19-2010, 11:34 AM   #12
mJUSTINm
well since they're stock links, and everyone posted about quick disco's.. here's what you can do.
unbolt the sway bar links from the axle side and swing the whole thing up. get some zipties and strap the links to something. on my stock LJ i usually ziptie it to a little bracket thats on the spring perch that keeps it out of the way of everything.
-Justin | Bruised LJ Build
mJUSTINm is offline   Reply With Quote
Old 01-19-2010, 11:38 AM   #13
Deacon
Purveyor of Funk
Deacon's Avatar
NOTE: If you're going to do this, make sure they are HEAVY zip ties, as I've had zip ties fail many times. I finally just got the stow pins that were supposed to have come with my TeraFlex disconnects anyway.
Deacon is online now   Reply With Quote
Glock Forum
