where do these go? - JeepForum.com
post #1 of 14 Old 07-25-2013, 12:10 PM Thread Starter
jeepwrangler97
I have some questions. ..I'm trying to fix all the little things that a shop did awhile ago.
First: where is this line off the intake manifold supposed to go? The lower arrow is where it connects & the upper is where it's just capped with a bolt:
The other lines go to the brake booster/master cylinder, & then the vacuum canister
The second thing is on my emissions canister/evap thing. All the lines are a mess & the middle part isn't hooked to anything:
Specs in profile, but 97 TJ 4.6L stroker, 00+ intake manifold. It's an early 97, made in early 96 if that matters.
No codes & runs well
Thanks JF
Sent by a messenger bird
jeepwrangler97 is offline
post #2 of 14 Old 07-25-2013, 07:14 PM Thread Starter
jeepwrangler97
Nighttime bump
post #3 of 14 Old 07-26-2013, 12:38 PM Thread Starter
jeepwrangler97
Bueller
post #4 of 14 Old 07-26-2013, 12:50 PM
AllTerrainJK
If no one replies before I get home at 6:30 I'll look at my jeeps and see where they go.
Roads? Where we're going we don't need roads!
AllTerrainJK is offline
post #5 of 14 Old 07-26-2013, 12:54 PM Thread Starter
jeepwrangler97
Cool beans. I appreciate it!
post #6 of 14 Old 07-26-2013, 01:11 PM
SlackJaw
baby jeep
SlackJaw's Avatar
yeh i'd a liked to help you but all that is pretty different than my '04....except the lower arrow on the first pic...IF it's the same, then that goes across the firewall to another "T". It controls the HVAC vent selection, and the "T" at the firewall is to a vaccum canister under the battery tray.
I have no idea what that thing capped with a bolt is, and the evap is in the rear fender well on my 04, so no help there.
Best wishes.
SlackJaw is offline
post #7 of 14 Old 07-26-2013, 06:45 PM
AllTerrainJK
I looked at both my 98 and my son's 00 and neither one match your set up exactly. Our evap canisters are rectangular and mounted on the inner fender well. Maybe I'm looking at your pic wrong, yours looks round and near the firewall.
Regarding the first pic that line runs from the manifold port to the line I'm holding in my pic. That's the evap can from my son's 00. It is off because we are restoring it. Sorry I couldn't help more.
post #8 of 14 Old 07-26-2013, 06:50 PM
AllTerrainJK
Well I can't get the pic to post. I'll try to figure it out.
post #9 of 14 Old 07-26-2013, 07:50 PM Thread Starter
jeepwrangler97
Best wishes.
Thanks. Yeah, one of the lines goes to my HVAC/vacuum canister stuff. I have no clue where the capped one is supposed to go.
post #10 of 14 Old 07-26-2013, 07:53 PM Thread Starter
jeepwrangler97
Thanks, I appreciate the help.
Yeah, mine is round & supposed to be on a bracket on the driver side fender. The round canister might be an early 97 thing. .. which might make this harder.
post #11 of 14 Old 07-27-2013, 07:17 AM
SlackJaw
baby jeep
SlackJaw's Avatar
If that's the case you might find luck asking YJ...just a thought.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #12 of 14 Old 07-27-2013, 08:28 AM Thread Starter
jeepwrangler97
I may have to try that. ...it gets confusing which parts are YJ parts, which are early 97 parts & which are 98+ parts, on an early TJ
post #13 of 14 Old 07-27-2013, 10:01 AM
Jonny Jeep
Jonny Jeep's Avatar
Do you not have an emissions diagram stuck to the hood? For some reason my phone's playing up and won't save an image to put on here.
The charcoal canister on the fender should have one line going to the fuel tank. That's from the left side (as seen in your picture) on your canister, and it should disappear below the intake manifold, and route to the tank. The other side of the canister where you have a pipe missing should go to the top of the evap solenoid which I don't see in your pic, though it looks like you have a pipe connected next to there which shouldn't be there. The pipe from the bottom of the evap solenoid should route to the intake manifold below the map sensor.
Edit: phone sorted itself out...
Jonny Jeep is offline
post #14 of 14 Old 07-27-2013, 11:56 AM Thread Starter
jeepwrangler97
Cool, thank you. I will have to go out & look at it. I think what you're saying might suggest that the capped line on the manifold should be a line coming from the bottom of the evap solenoid..
No, I don't have an emissions diagram on my hood. I boughty jeep after an incident with a tree & the front clip is all cheapo aftermarket stuff the PO put on
