Quantcast where did you mount your co2 tank? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > where did you mount your co2 tank?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 04-16-2007, 09:50 AM   #1
bigV
anyone have pics? I'm looking at getting a 20# tank soon. Any custom brackets made?
bigV is offline   Reply With Quote
Old 04-16-2007, 10:31 AM   #2
Baotchi
2010 JK Wrangler
A 20# is a big tank. That is what I have also, not installed yet. I am still collecting parts and waiting to get it filled.
I will probably install it horizontally in the back of the jeep in the "trunk" area with a secured panel over it. I'll take the tank out to use it because I think it has to be vertical to flow right. (maybe this aint right tho...)
You can order a specific bracket from www.powertank.com that will fit a 20# bottle and that is really nice, but too expensive for me.
I will end up fabbing a bracket myself with quick disconnects to put it in/take it off easily.
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline   Reply With Quote
Old 04-16-2007, 10:34 AM   #3
bigV
I heard the same thing
Old 04-16-2007, 10:56 AM   #4
PullMeSideways
2010 JK Wrangler
I mounted mine to the back passenger side corner. I used the powertank bracket that came with the tank.
2010 2dr Rubicon - Mango Tango!
Colorado Jeep Club Member #11
Former Jeeps:
2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7
PullMeSideways is offline   Reply With Quote
Old 04-16-2007, 11:03 AM   #5
bigV
I have a subwoofer box that fills that whole back area behind the seat, so I'll have to come-up with another spot. I like the fact that you used your seat bracket for a tool box mount, I had a similar idea, but your's looks easier.
Old 04-16-2007, 11:43 AM   #6
beep-ima-jeep
Okay,
will someone please explain to me what Co2 is for? I use it for paintball, and air cannons, and my uncle for beer making, but what else (jeep related)?
beep-ima-jeep is offline   Reply With Quote
Old 04-16-2007, 11:51 AM   #7
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I would not get a 20lb tank. That is wayyyyy big, as said above. I have a 15lb tank. It was mounted on the inside on the back of the roll cage so that it was sitting on the wheel well behind the driver. My kids complained because you could not see out.
I have since mounted it on the back. It is easily removable.
www.jeepforum.com/gallery/files//4/9/7/6/5/Flex3.JPG
www.jeepforum.com/gallery/files//4/9/7/6/5/Tank1.JPG
The 15lb is really too big for a wrangler. I would go with a 10lb if I had it to do over again.
If you mount it on the outside, make sure it is tucked in close to the spare so that you do not hit it on anything, or take it off entirely for more extreme trails.
Originally Posted by beep-ima-jeep
Okay,
Airing up tires
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 04-16-2007, 11:54 AM   #8
bigV
Okay,
fill-up tires, run air tools
Old 04-16-2007, 11:59 AM   #9
bigV
thanks for the pics paultyler, that 15# tank does look plenty big. I want to run air tools as well as fill-up tires - how many tires can you do before you have to re-fill the tank? I have 33's and I need 72psi for my fill-ups (12psi to 30psi x 4), plus a few of my friends don't have any air-up devises (I'm trying to get them into serious off-roading) so I'll be airing up their rigs too, I have a small 12v compressor that takes me 3 minutes per tire, I like the 30sec per tire time better
BTW, nice looking rig
Old 04-16-2007, 12:02 PM   #10
paultyler
paultyler's Avatar
If I recall correctly, I can fill 46 tires from 11 psi to 28 psi on a 15 LB tank. So that is like 11-12 trips. There is a chart here http://powertank.com/charts.specs
My Jeep - Video
My Jeep in the Snow
Old 04-16-2007, 12:02 PM   #11
newracer
newracer's Avatar
Mounted mine on my Wilderness rack/tire carrier
newracer is offline   Reply With Quote
Old 04-16-2007, 12:28 PM   #12
Tumble
I also have a 15 pound take and wish I had gone with a 10 pound. I still think my 15 is massive what the amount of wheelin' I do.
Mine is mounted on the passenger side in the cargo area:
Tumble is offline   Reply With Quote
Old 04-16-2007, 12:43 PM   #13
mdm
Farm Wheeler
...I'll take the tank out to use it because I think it has to be vertical to flow right. (maybe this aint right tho...)...
You can mount it at an angle but it must be upright before use. The CO2 is in a frozen liquid state. If the tank is at enough of an angle for the liquid to be at the neck of the bottle you get liquid CO2 out instead of gas.
mdm is offline   Reply With Quote
Old 04-16-2007, 02:53 PM   #14
98teej
Personally, I don't see anything wrong with getting a 20# tank if you can. Specially if you can get it for a good deal. If you can fit it in your Jeep, why not. You have the advantage of less trips to refill it. I mounted my 20# tank laying down on top of my insta trunk supported with a tank brace I got from a welding shop. Of course I have to take it out before I use it so its upright.
Gunmetal 98 TJ 4.0*3-Spd. Automatic 32RH
*D30 Aussie Locker*Superior S35 kit w/ Detroit locker*Superior R&P 4.56*D30 / D35 Rockcrusher*REBB 2" 2.75" in the front*JKS 1.25BL*RE Steering Stabilizer*Skidrow Engine skid plate*AA Shifter Bracket*Homefabbed Co2 tank setup*Homefabbed quick discos*BFG MT 33x12.5x15 on 15x8 AR*
1998 4.0 Sport TJ
2006 Jeep Commander Limited 5.7L Hemi
98teej is offline   Reply With Quote
Old 04-16-2007, 02:59 PM   #15
bigV
I can get a 20# tank a few dollars cheaper than a 15#, the salesman didn't know why, maybe supply/demand
Glock Forum
