Where did you hook up the little wire for an electric fan? - JeepForum.com
post #1 of 6 Old 02-11-2016, 05:31 PM Thread Starter
Paxter
I can't seem to find the answer anywhere and I'm sure it's so simple...yet I am so bad with electrical. I'm waiting for my new thermostat control box to come in the mail and in the mean time I need to have a fan going. So my question is, where did you hook up the little 14 gauge wire so that when I turn the ignition on, the fan comes on, and when I turn it off, the fan shuts off. This is out of a 99 wrangler 4.0l
Paxter is offline
post #2 of 6 Old 02-12-2016, 02:39 AM
mukluk
Assuming you're talking about a non-factory electric fan for your radiator (since all 4.0L TJs originally had a mechanical fan and viscous clutch bolted to the water pump), the most logical place to tie in the wire would be to the fuel pump relay output -- you would have power any time the engine is running.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 6 Old 02-12-2016, 07:09 AM
2jhanna
If you want to simply have it come on/off with the ignition, you could use any assy switched power, like radio or similar, to pull a relay to provide fan power.
Doesn't a '99 have extra leads behind the glovebox?
jhanna
denton county, tx
2jhanna is offline
post #4 of 6 Old 02-12-2016, 07:32 AM
JWebber
yes 99 TJ's have a switch power lead and a constant direct and are labeled or should be.
JWebber is offline
post #5 of 6 Old 02-12-2016, 07:53 AM
2jhanna
OP, there you go, use the switched power lead to pull in a relay with new fused power from the battery to operate the fan.
jhanna
denton county, tx
2jhanna is offline
post #6 of 6 Old 02-12-2016, 03:20 PM
smccollamjr
Definitely use a relay.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline
