??where is the CAMshaft position sensor on 02 tj?? - JeepForum.com
post #1 of 2 Old 06-11-2007, 11:47 AM Thread Starter
02tjsport
2014 KL Cherokee
Got the codes P0340 and P1391. One of them is the camshaft position sensor. I dont have a distributor, so where the heck is it? I just replaced the CKP cause i misread the darn scan tool.
Please help
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline
post #2 of 2 Old 06-11-2007, 01:11 PM
TJinWV
TJinWV's Avatar
It's on the oil pump drive where the distributor "should" be. Just two bolts holding it on.
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 20 07-31-2017 12:22 PM
Camshaft position sensor? wolfstyle TJ Wrangler Technical Forum 1 08-16-2009 07:40 AM
Camshaft position sensor 94 YJ 2.5L FI ChiroSean YJ Wrangler Technical Forum 5 11-01-2008 05:55 PM
camshaft position sensor? LeftoverSalmon TJ Wrangler Technical Forum 7 07-08-2008 11:01 AM
Does 97 TJ have Camshaft Position Sensor? spdrmn44 TJ Wrangler Technical Forum 2 08-30-2007 04:40 PM
