where to buy line-x ? - JeepForum.com
post #1 of 8 Old 01-19-2006, 04:11 PM Thread Starter
jdelow77
anyone know where to buy line-x but the can, i have talked to a local shop and all they do is spary it for you, they wont just let you but the coating, anywhere on line that sells the stuff? i have a place to do it and the under coating gun just need the line-X!
jdelow77 is offline
post #2 of 8 Old 01-19-2006, 04:13 PM
bfr
bfr's Avatar
I would be shocked if you could buy it (line-x brand) without becoming a dealer and making an initial buy in.
bfr is offline
post #3 of 8 Old 01-19-2006, 04:13 PM
JeepCreepn01
JeepCreepn01's Avatar
line-x is sold to dealers only, trying herculiner or the other kinds you can actually buy
JeepCreepn01 is offline
post #4 of 8 Old 01-19-2006, 04:28 PM
hol
Line'x has to be applied with certain equipment. Duraback is a pretty good do it yourself option.
2000 Sahara, 33x12.50 BFG AT's, Black American Racing steel rims, 4" BDS lift, Warn XD9000i, Custom Front bumper, Blue Ridge Offroad Rock Rails, Warn swing away tire carrier, 4to1 transfer case, many other odds and ends.
hol is offline
post #5 of 8 Old 01-19-2006, 05:03 PM
blissburn
Line-X can't be applied with an "undercoating gun". It is a binary mixture that is applied at high temperature with high pressure and solidifies within a few seconds of the 2 parts being mixed. The people who spray it in actually have to be trained how to do it properly, they take the time to do it right, and they stand behind their work. This, IMHO, is what sets Line-X apart from the other types of lining.
If you are set on a do-it-yourself approach, spray on either Herculiner or Durabak. If you take your time and do it carefully, the results will look really good. It won't be quite as durable as Line-X, but it should be "good enough".
A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of handguns and tequila.
blissburn is offline
post #6 of 8 Old 01-19-2006, 05:07 PM
TJ on the Rocks
TJ on the Rocks's Avatar
Line - X is applied at an average of 2200 PSI at around 400 degrees and dries in 5 seconds . How you gonna do that ? Go to this link and find an installer in your area
: http://goline-x.com/index.shtml
TJ on the Rocks is offline
post #7 of 8 Old 01-19-2006, 09:46 PM Thread Starter
jdelow77
ok so the line-x thing wont go over very well, i want something that is gonna be thick and have a rubber texture to it when dry, what do u guys think it would be?
jdelow77 is offline
post #8 of 8 Old 01-19-2006, 10:51 PM
TJ on the Rocks
Maybe this will interest you ................click the link below
http://www.duplicolor.com/products/truckbed.html
Vacuum line ID?? Line dragging on the ground.. Gunmetal YJ Wrangler Technical Forum 4 01-21-2010 05:07 PM
Fuel Line or Return Line GrantYj88 YJ Wrangler Technical Forum 8 01-09-2010 02:05 PM
EGR Line/ Vapor Line Question KRenegade YJ Wrangler Technical Forum 6 01-08-2010 02:51 PM
Rhino Line or Line-X Exterior of Hardtop? 007WRANGLER TJ Wrangler Technical Forum 5 09-05-2007 10:14 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 08:24 PM
