When to upgrade stock wheel - JeepForum.com
post #1 of 14 Old 02-24-2006, 01:29 PM Thread Starter
Gun_Runner
Ok I checked the FAQ's section dealing with how big of a tire can I go on my TJ etc etc.
Nothing addressed the issue of Offset. is there an issue?
Assuming a 3.5 inch RE flex kit or equivalent lift at what tire width would I need to start thinking about Offset?
How wide can I go with the stock Rubicon Moab rims with say 33inch tires??
thanks in advance I could not find the info posted on the site.
OMG! Did you hear they have the internet on computers now?!!?
Gun_Runner is offline
post #2 of 14 Old 02-24-2006, 01:42 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
11.50 would be the max width on Rubi Moab wheels. BTW, they have 5" of backspacing.
If you want to run the more commonly found 12.50 width in the 33" size, you want 4.5" of backspacing or less.
Translated to offset, this would be -12.7mm or more (as in more negative, for example -20mm).
Wheelin98TJ is offline
post #3 of 14 Old 02-24-2006, 01:51 PM
Bobby G
Bobby G's Avatar
go with a 33 x 12.5 and 4.5 back spacing
H2RT Pimp Master
2000 SE
LIFT, TIRES, BROKE.
Orange Jeep Club# ?
Bobby G is offline
post #4 of 14 Old 02-24-2006, 04:59 PM
JoonHoss
2011 JK Wrangler
Or,if you do want to keep your stock rims, you could go to 33 X 12.50's, but you'd have to run wheel spacers, or you could run 33X10.5's.
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #5 of 14 Old 02-25-2006, 09:48 AM Thread Starter
Gun_Runner
so which is it?
Wheelin98TJ says 11.5's are tha max on a stock rim and
Joonhoss71 says 10.5's
If I did the wheel spacers and 33X12.5's what am I likely to break?
Thanks in advance
post #6 of 14 Old 02-25-2006, 10:57 AM
Wheelin98TJ
JEEP FREAK
10.50 is the max width on most TJ wheels that have 5.5" backspacing.
You need 5" or less bs to run 11.50 wide tires, which Moab wheels have.
33x11.50 is not a common size, but since they are 16" wheels, you should be able to find a metric sized tire that is pretty close to that size.
post #7 of 14 Old 02-25-2006, 02:39 PM
Expat
Frequent flyer
Expat's Avatar
Thanks in advance
Nothing as long as you go with quality spacers that are HUB CENTRIC such as Spidertrax. The thing you run into there is that for very little more than the cost of quality spacers you can get a nice set of aftermarket wheels. You can get black steelies cheaper than spacers. Choice is yours.
05 RME Fire Red
3.5" RE springs, JKS F&R adj track bars, JKS adj CAs (all 8), OME LT shocks, JKS quicker discos, JKS 1.25" BL, MORE BP MML, 35" Cooper SSTs on 057 Eagle Alloys, 4.56s Detroit lockers, Alloy USA front and rear axles, Currie HD steering, 52" Hanson front bumper, Warn 9.5ti with in-cab control, Kilby steering box skid, Jeeperman rear bumper/tire carrier, Jeeperman trail skidz, 33 Eng TT, JB SSSYE, TW driveshaft, and lots more........
2007 WK Overland Steel Blue..wifes
1997 ZJ Laredo...sons
2004 GMC 2500 HD Duramax Diesel..My TV and DD and Lance camper carrier
2003 Chaparral 223 deck boat
Originally Posted by kjp98TJ
drop the purse, and hit it.
Expat is offline
post #8 of 14 Old 02-25-2006, 02:58 PM
MCanavan
Too bad Jeeps aren't hub centric and the spidertrax spacers are just a marketing scheme. Any set of wheel spacers should be fine as long as they are quality. IT depends on how much you want to spend, they range from $55/set on ebay to $130/set for spidertrax.
MCanavan is offline
post #9 of 14 Old 02-26-2006, 09:21 AM
Expat
Frequent flyer
Expat's Avatar
You need to do more research my friend.
05 RME Fire Red
Expat is offline
post #10 of 14 Old 02-26-2006, 09:44 AM
rhelton04
rhelton04's Avatar
Hey, I don't mean to hijack...but I'm looking at getting some black Cragar 397's today.
Just so I'm sure - I have 31x10.5's but will probably upgrade to 32x11.5's with the next tire purchase. Should I go with 5.0 backspacking for my cragars? That will work with what I have AND work when I upgrade?
Thanks!
04 X
31x10.5 Wrangler AT/S
RE 2" BB
LOD Rocker Guards
Black - You mean it comes in other colors?
rhelton04 is offline
post #11 of 14 Old 02-26-2006, 10:57 AM
Wheelin98TJ
JEEP FREAK
Thanks!
I'd go with 4.5" bs so you have the option to run 12.50 wide tires down the road.
And 1/2" more bs shouldn't be that big of a deal, unless your state is REALLY strict on tire coverage laws.
post #12 of 14 Old 02-26-2006, 11:24 AM
NoUse328
285/75/16's are a VERY common tire size with Rubicons. All you have to do is mount them and adjust the steering stops. Plus you get to keep the Moabs.
NoUse328 is offline
post #13 of 14 Old 02-26-2006, 05:35 PM
schnouse
Check out http://www.finishlinewheels.com for OEM Alloy Wheels and Jeep Replica Rims.
schnouse is offline
post #14 of 14 Old 02-26-2006, 07:26 PM
rhelton04
rhelton04's Avatar
Read the rules or get lost.
04 X
RE 2" BB
LOD Rocker Guards
06 TJ SE Wheel and Tire Upgrade CKTrpt TJ Wrangler Technical Forum 5 08-15-2008 09:00 PM
Wheel Question / Stock YJ Upgrade BlackSheep92 YJ Wrangler Technical Forum 8 06-18-2008 10:00 AM
What is the Best Wheel to upgrade my Jeep? juanplopez YJ Wrangler Technical Forum 25 06-08-2006 05:18 PM
30 in Wheel / Tire upgrade BostonJeepah TJ Wrangler Technical Forum 35 07-07-2003 08:34 PM
wheel upgrade question..... realmenraceoffroad TJ Wrangler Technical Forum 2 04-25-2002 04:54 PM
