when to replace tie rod ends? - JeepForum.com
post #1 of 7 Old 04-04-2012, 10:20 AM Thread Starter
jeepinjeffrey
So I just got a ZJ V8 tie rod and drag link to replace my stock hollow TJ one and how do i know if I should replace the tie rod ends or if they're good? Thanks
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #2 of 7 Old 04-04-2012, 10:25 AM
extsp2
Did you get new or used? I'm assuming used. You didn't need the drag link as there is not much difference between the stock TJ and ZJ links. Did you check for play in any of the joints before you bought it? They get replaced when they have play, it's not like a fluid that you change at regular intervals. For the cost of the new tie rods from places like NAPA and Advance I wouldn't buy used. JMO.
"Even duct tape can't fix Stupid"-Ron White
extsp2 is offline
post #3 of 7 Old 04-04-2012, 10:32 AM Thread Starter
jeepinjeffrey
A new one from auto zone was $63 I got mine for $15 hence the used:/ I wish I got a new one but yea i can move the bolt around by hand in the circular motion but it probably has lost all its grease so im not sure if that would make it move a bit. It was stiff at first but aster a little push I can spin it around. does that mean there gone? My TJ only has 25,000 should I just swap mine back over or see what one moves less?
2003 Wrangler Sport
post #4 of 7 Old 04-04-2012, 11:14 AM
extsp2
It's kinda hard to check tie rod ends unless they are mounted in a vehicle. Just because you can move it around by hand doesn't mean that it's good or bad. Have you already mounted the assembly in your Jeep?
extsp2 is offline
post #5 of 7 Old 04-04-2012, 11:19 AM Thread Starter
jeepinjeffrey
No I havnt yet I was hoping to replace it before if needed. So I should install it first?
2003 Wrangler Sport
post #6 of 7 Old 04-04-2012, 12:31 PM
extsp2
at this point yes. it's risky buying some parts at the junkyard.
extsp2 is offline
post #7 of 7 Old 04-04-2012, 09:52 PM Thread Starter
jeepinjeffrey
ok ill replace! Thanks! better safe them sorry!
2003 Wrangler Sport
johnny joints to replace replace re rubber cmc1 TJ Wrangler Technical Forum 6 06-16-2009 04:50 PM
Replace Tie Rod & Drag Link Ends, or Currie? cvd TJ Wrangler Technical Forum 2 01-19-2009 05:55 PM
Time to replace rod ends Fun2Jeep YJ Wrangler Technical Forum 13 09-06-2008 08:59 PM
pavement ends replace a top and rear window rrclimber TJ Wrangler Technical Forum 2 06-05-2006 12:34 PM
headlight out, can I replace the bulb or do I need to replace the whole assembly? illumin8em TJ Wrangler Technical Forum 2 02-24-2004 12:21 PM
