When to replace the O2 sensor? - JeepForum.com
post #1 of 14 Old 11-22-2007, 09:24 PM Thread Starter
Sakislayer
Guys I have a 98 TJ with 112K+ on it and it runs fine. However, it seem my gas mileage has really started to go into the crapper.... I was wondering if might be partly caused by the O2 sensor?
When should they be replaced? My jeep runs great and doesn't have any check engine lights or codes.... The O2 is the original....
Thanks in advance! OH - and is this a self project? or take it to the shop? I know it just screws out, but given my jeep is 10 years old I'm sure it's in there nice and tight....(ugh)
Mike
1998 Jeep Wrangler Sahara
2.5" TeraFlex 2T lift, 1.25" Tera-spacers, 1" Tera Bodylift 32x11.5 BFG ATA's
Sakislayer is offline
post #2 of 14 Old 11-22-2007, 11:26 PM
97tjtom
change em. its a do it yourself job with some PB blaster every day a few days before
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #3 of 14 Old 11-23-2007, 12:03 AM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Hey, I'm actually over in North Hollywood. Personally, I'd let it go. When the o2 sensor goes bad, the check engine light will come on. That's what happened with mine when I first bought it. It would come on and off, it failed the smog test because it was giving out faulty readings. As long as you're passing the smog tests and the check engine light is on, your O2 sensor should be fine.
When it DOES go, its a very simple procedure. Since it's a southern car, there shouldn't be much rust, worst case, spray a little WD-40 on it. But mine is a 97' with 70k and it took me all of 15 minutes to unscrew it and replace it.
As for your gas mileage, make sure you use Chevron, Shell, Mobil, etc. Stay away from Amco or those cheap ones, they have a lot of additives in the gas that leave deposits. I had the it professionally burned off of the heads and intake. You can try other things like changing the air filter, spraying out the throttle body, and maybe a bottle of injector cleaner, (I've heard good things about the Lucas Tune-up in a bottle)
Other things, if the wheels aren't balanced, that will cause a decrease in mileage. Same with the oil, if it gets sludgy, it will slow things down.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #4 of 14 Old 11-23-2007, 02:25 AM
bigchevyman24
bigchevyman24's Avatar
When you get an extra $70...lol...
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #5 of 14 Old 11-23-2007, 06:09 AM
Davejb
o2 sensors are not maintenance items, when they go bad the MIL (check engine light) will come on.
2006 Wrangler Unlimited
Vote Quimby
Davejb is offline
post #6 of 14 Old 11-23-2007, 12:00 PM
TMJeep
They will not always give you a code saying it is bad. Mine started going bad and it would spit and sputter when I would first start to drive it and about backfire. I replaced it after trying different gas and things like that and has run perfect since. I even took it to get the codes checked and it never had any.
You can buy them from www.oxygensensors.com . They were the cheapest I found and get the OE fit not the universal fit.
98 Sport TJ 4.0L
Chile Pepper Red with Black Dual Tops
Trueflow Air Filter
31" BFG A/T
Cibies headlamps, plus 30 bulbs
other than that pretty much stock for now
TMJeep is offline
post #7 of 14 Old 11-23-2007, 12:23 PM
HipCheck_1
x2. I would change the o2 sensor around 80,000-100,000 miles.
HipCheck_1 is offline
post #8 of 14 Old 11-23-2007, 01:19 PM
redvett94
Its recommended to change the O2's at 100000mi because they will get lazy and not toggle quickly. The SES light will only go on if post O2 indicated poor cat. performance or the pre O2 completely dies. You just need to replace the pre O2's for economy & performance. The post O2's only monitor the cat. performance.
2000 Sport.
redvett94 is offline
post #9 of 14 Old 11-23-2007, 01:53 PM
fish4life
Thanks for that link. My O2 sensor has recently gone bad and i DID get a Check Engine light! The engine light went away after a few days, but even now when i scan the codes it still shows up as "upstream oxygen sensor" even with no light.
I was just about to buy a new sensor here, and they want around $100 in Canada for them. Given the strength of the canadian dollar now, That oxygensensor.com site comes to half price of the local shops. Needless to say, i'll be ordering from those guys
btw, my jeep only has 75,000 miles on it, and the thing went
fish4life is offline
post #10 of 14 Old 11-23-2007, 01:54 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
redvett94 is right on.
Around 100k miles they're to the age where they start to get sluggish. The sensor will still perform within the parameters of the OBD II system and a check engine light will not be set off.
Replacing the upstream sensor(s) can improve your mileage. If you still have the original sensor, there's a real good chance that it will.
Wheelin98TJ is offline
post #11 of 14 Old 11-23-2007, 03:20 PM
Rocky.ca
i didnt get any sort of CEL when my 02 sensors kicked the bucket. I picked both the up / down stream sensors at autozone and noticed a considerable increase in gas milage and a complete removal of the "sputtering" that all 4cyl 97 tjs get. its only like $130 for both, just change em out.
Black 97 TJ SE 4bangin' away.
3" BDS lift
33" A/Ts
Sound System
custom de-milk jugged bumper :D
Rocky.ca is offline
post #12 of 14 Old 11-23-2007, 04:29 PM
fish4life
lol ... yeah ... only like 130 ...
post #13 of 14 Old 11-23-2007, 05:58 PM
Rocky.ca
oh yeah lol... i forgot, the us dollar took a DIVE. i bought mine w/ my Canadian currency and it seemed like a huge deal to me (i saved about 80 bucks). :P
3" BDS lift
33" A/Ts
Sound System
Rocky.ca is offline
post #14 of 14 Old 11-24-2007, 05:55 AM
Davejb
I should have said you will usually get a MIL, my bad. Most of the time they cause something to go out of whack that the computer will pick up, but it may not specifically point to the sensor.
Vote Quimby
Davejb is offline
O/2 sensor... how to replace? BChamberlin TJ Wrangler Technical Forum 24 08-11-2006 02:20 PM
How to replace oil pressure sensor aeguy010 TJ Wrangler Technical Forum 4 07-07-2006 07:36 PM
Should I replace my o2 Sensor ? sunny_8 YJ Wrangler Technical Forum 8 10-21-2005 02:03 PM
Need to replace 02 sensor before cat, can i do it ? chaznad TJ Wrangler Technical Forum 8 10-05-2005 11:24 AM
Replace O2 Sensor? Nater018 YJ Wrangler Technical Forum 4 04-14-2005 09:29 PM
