When do you shift? - JeepForum.com
post #1 of 33 Old 02-18-2010, 08:35 AM Thread Starter
JEEPBURGH
When do you shift?
I have a 4 cylinder TJ and as we all know I didn't buy if for power!
I just wanted to take a talley on how high people run ther RPM's before they shift. I've been shifting between 3000-4000 RPM's and I tend to get a bit more power in 3rd-5th at higher RPM's. Did I mention that my TJ is a 6 speed?
Thanks!
JEEPBURGH is offline
post #2 of 33 Old 02-18-2010, 09:10 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
when do you shift?
When I see a cloud of smoke coming from the rear.
TheBoogieman is offline
post #3 of 33 Old 02-18-2010, 09:43 AM
Dmcastino
3-4k is probably a lil high to shift you are looking for decent mileage (well decent considering its a Jeep). I probably shift a little high for good mpg too and I shift between 2500-3000 usually, but I am driving a 6 cyl with a 5 speed
Dmcastino is offline
post #4 of 33 Old 02-18-2010, 09:45 AM
tavic
2010 JK Wrangler
Depends on the situation and how lazy I'm feeling that day...
tavic is offline
post #5 of 33 Old 02-18-2010, 09:46 AM
jeepinmichguy_
mine shifts for me.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #6 of 33 Old 02-18-2010, 09:55 AM Thread Starter
JEEPBURGH
No automatics!!!!
post #7 of 33 Old 02-18-2010, 10:00 AM
Imped
Imped's Avatar
Your 4 banger makes its power up high, so you should be shifting in the 3-4k range. It won't effect your mileage like some will say. Your mileage will be poorer if you lug the engine and shift at 2k. With 4.88's, 35's, 4.0, and NV3550 I shift in the 2.5-3k range. I'm not a fan of lugging the engine and I get better mileage than most.
OlllllllO
IndyORV
Imped is offline
post #8 of 33 Old 02-18-2010, 10:01 AM
patricknolan
between 2300 and 3300. I only really need the higher end 3k and up when im in 3rd gear, or 4th gear. I dont use 5th gear
patricknolan is offline
post #9 of 33 Old 02-18-2010, 10:03 AM
06WranglerX
Between 2,200 and 2,500 rpms around town, 3,000 rpms when I am on a on ramp for the highway, but I have a 4.0 with 4.56 gears.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #10 of 33 Old 02-18-2010, 10:04 AM
vindicated
Did you miss me?
vindicated's Avatar
I dont have the 4 I have the 6cyl 6 speed, but I still usually shift around 2200-3000 for mileage purposes. And I rock the nonsense out of 6th gear. I feel like on the highway and even around 50 mph there is alot of power in sixth still. I am running 3.73 gears though so I dont know if that matters....
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #11 of 33 Old 02-18-2010, 10:06 AM
slafferty
when i hit the rev limiter.......
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #12 of 33 Old 02-18-2010, 02:05 PM
BlueFlame
BlueFlame's Avatar
Thanks!
Even though many will answer, the question as asked has no correct answer.
You do not shift at a certain same rpm each time.
For each gear change it will be different (you typically rev higher between 1-2 and 2-3 shifts than you do for 4-5 and 5-6), and for different driving situations the appropriate shift point will be different.
For example, when you pull onto the freeway you need to rev between shifts to get up to speed quickly.
But when you just turned onto a street and are going to have to stop at the light a half block down, what sense does it make to rev to 4 grand?
EVERY single shift, EVERY time, must be decided by you; shift early because not much power is needed or economy is desired, rev high to accellerate quickly, or - typically - somewhere in between.
Note that shifting too early can actually reduce mileage due to lugging the engine. Listen for it, the engine will tell you when it's not breathing well.
BlueFlame is offline
post #13 of 33 Old 02-18-2010, 02:18 PM
jdub2k5
in most my cars I shift at the same rpm in every gear the jeep is weird in the sense that I change gears at random rpms.
I try to stick to around 3k-3.5k(power for the next gear, good exhaust sounds, and smooth shift)
2004 TJ 4.0 5 speed, 2 inch body lift, barricade armor, 4.5 bds lift, 35 mtz, sye, and tons more
jdub2k5 is offline
post #14 of 33 Old 02-18-2010, 02:21 PM
The27Jeenyus
i have 4.0 6 speed and i shift just ~ 2100
Zach
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline
post #15 of 33 Old 02-18-2010, 02:27 PM
krawler510
As said before it depends on the situation but in general, on an open road always over 3k in my 4 cylinder. Lugging the engine is worse than revving it up a bit more.
I usually even take my 4.0L to 3k on a regular basis. And my Civic sees anywhere between 4k and 8200, based on my mood and desire for adrenaline.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 08:26 PM
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 07:31 AM
Can't Down Shift into 2nd or 1st, but when stopped, it will shift MarkkInNJ YJ Wrangler Technical Forum 8 07-03-2009 09:48 PM
How to separate upper shift lever from lower shift lever??? rgs112 YJ Wrangler Technical Forum 3 08-11-2008 05:59 PM
Doesn't shift into 4WD ORANGE_06_LJ YJ Wrangler Technical Forum 5 02-14-2005 08:54 AM
