when clutch is not depressed i hear abunch of stuff rattling around in my tranny....
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
but when i press the clutch down it becomes quiet. and it is loud clanking when not pressed
NIGHT CREW #16 Yellow Jeep Club #67 My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/ THANK YOU TO 97tjeff, Metalcloak!!! |
#2 |
You're going to have to pull the transmission, but if the pilot bearing is on it's way out, it can rattle when no pressure is on it, (aka in gear) and when you push the clutch down, it gets pressure on it, so it will shut up.
Jeep TJ. Stuff added to it. Stuff broken. More stuff added to it. More things broken. Currently in adding phase. Hope to be in breaking phase on trails soon. |
#3 |
so its in the broke or breaking phase hscrugby???
#4 |
Is it doing this in Neutral or in all gears? I am having the same problem in Neutral. I did a little checking and found a TSB for what seems to be something with the Transfer Case Shifter Causing Excessive noise from the tranny. Im yet to go to the dealer ro find out more about it yet though. Also I just did a full fluid swap on mine and I put Royal Purple Syncromax in my trany and that cut back on alot of noise I was hearing and also the shifting is alot smoother.
#5 |
my shifting is real hard when i do drive there is a weird whine noise and what i am reading it seems to be my pilot bearing im guessing
#6 |
it whines/squeals when i start going any ideas!!!!!!!!??????????????
#7 | |
it will take you ~30 minutes-1 hour to pull the transmission and check everything.
#8 |
alright ill check around
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
