wheels swap on a 03 - JeepForum.com
post #1 of 2 Old 07-16-2010, 08:06 AM Thread Starter
frank1
2005 WK
wheels swap on a 03
whats the best way to go in changing the wheels on my 03 wrangler-i would like 16'' instead of 15''-was looking at adapters buy have never used them before and their seems to be a lot of used wheel and tire combinations out there off the newer jeep,but they have the larger bolt pattern. looking for some one who has done the swap and any problems that were encountered
frank1 is offline
post #2 of 2 Old 07-16-2010, 08:41 AM
Zen
The best way to go is to buy 16" wheels with your desired bolt pattern and back spacing. Adding a wheel addapter can be safe, but it adds one more (possibly weak) link in the system.
You need to decide what size wheel you need, then find what wheels are available in that specific size. What back spacing are you looking for? What width? Will the desired tire be compatable?
If you want OEM wheels, look for factory Rubicon Moab wheels or knock offs.
Mamba Offroad Alloys R16865S13 - Mamba Offroad Type MR-1 Silver Wheel for Jeep® Vehicles with 5x4.5 Bolt Pattern - Quadratec
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
wheel , tj , wrangler , bolt pattern , swap
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
2003 tj tires and wheels advice and swap jjsj38 TJ Wrangler Technical Forum 4 10-14-2009 12:41 AM
Picked my wheels, which size wheels and tires for a DD? JYogi JK Wrangler Technical Forum 7 09-11-2007 06:58 PM
Everyday wheels and Trail wheels...balancing problems? Tacoma750 TJ Wrangler Technical Forum 1 08-19-2006 07:31 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 12:10 AM
