Wheels Steel Vs. Aluminum - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Wheels Steel Vs. Aluminum
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 04-25-2002, 02:41 PM   #1
TimberViking
Alright, I have an opportunity to get a good deal on some stock TJ Canyon rims that are in good shape. I would use my stock 97' rims (30 inch wheel package), which I really like for everyday driving on my GYR AT/S's and the Canyon rims for some 32 or 33 GYR MT/R's (for off-road). Which would you go with for off-road, aluminum, or steel. Durability? Weight? 15" and backspacing is fine.
TimberViking (Belvidere, Illinois)
[U]2005 4.0L LJ Rubicon[/U]
4.5" R.E. Superflex Lift, JKS Discos, OME Shocks
Jeep Medic TT/Engine Skid, Kilby Gas/Steering Skids MORE BL/MML, Warn 9.5ti Hanson Bumpers
Mopar Rockers, Viair 450c Onboard Air (2 gallon)
TimberViking is offline   Reply With Quote
Unread 04-25-2002, 02:46 PM   #2
SunDawg
You actually have a chance to pound a steel rim back into shape if you clip a rock and loose your seal on the trail....that is the main pro for steel over alum.
[b][url="http://www.sundawg.net"]S u n D a w g[/url][/b]
'97 Jeep TJ Sahara Edition
-[i]RE 4.5" Lift[/i]
-[i]BFG KO 33x10.5r15 on AR-767 15x8[/i]
-[i]Tom Wood's Conversion Kit[/i]
SunDawg is offline   Reply With Quote
Unread 04-25-2002, 06:27 PM   #3
Patton
Aluminum is a little lighter est.10% and will absorb impacts a little better. I think it's a lot of bull but the manufactures use this as a selling point.
06 TJ X 4spd auto 3.73
4" pieced together lift
Patton is offline   Reply With Quote
Unread 04-25-2002, 06:48 PM   #4
gatorfish
If you go to a steel rim, you can get the proper back spacing so those 33's fit well. They are cheap, if you mess one up beyond repair, its no problem replacing it.
'99 XJ RE3.5
past:
XJs '87 '91 '00
TJs '01 '02
gatorfish is offline   Reply With Quote
Unread 04-25-2002, 09:00 PM   #5
Exocet
My TJ is only a year old, and I've already noticed rust forming on my spare wheel. I'm currently looking to replace them with aluminums.. rust after one year? No thanks.
Exocet is offline   Reply With Quote
Unread 04-26-2002, 05:34 AM   #6
SunDawg
Yup...rust is a problem. But fortunately it's extremely easy to repaint them
Unread 04-26-2002, 06:50 AM   #7
moneymercenary
Go with the Steel wheels and you will love the Goodyear MT/R's.
'01 TJ Silver Anniversary edition, Skyjacker 6" Rock Ready, 37" MTR's, Dana 30, Dana 44, Auburn pro series in rear, 4.56's, HS9500i, Bulletproof Winch Mount, Bulletproof FF1, Currie Swingout Tire Carrier.... and more
moneymercenary is offline   Reply With Quote
Unread 04-26-2002, 07:35 AM   #8
4wheeler4CJ
Depends on whether or not you will do alot of rock crawling.
I don't, and I have used the same set of Aluminum Wheels (Outlaw I 15x10's) on my CJs for over 8 years now, and they are going on my next '77 once it hits the road this summer. They always look good, and I never even waxed them, EVER!
When you call for wheels, just ask what backspacing they are available in, I used National Tire & Wheel back then, and they gave me the correct backspacing so i would get no rubbing, which I never did.
4wheeler4CJ is offline   Reply With Quote
