Wheels rub when i make tight turns.... - JeepForum.com
post #1 of 12 Old 01-21-2005, 11:40 AM Thread Starter
Danlawson
What do i need to do to fix this?
They are 32s (with a 2 inch lift) & only rub when i turn the steerign wheel too far.
Danlawson is offline
post #2 of 12 Old 01-21-2005, 11:43 AM
helix
helix's Avatar
32s wont fit a 2" bb... The max recomended for a 2"bb is 30s. for 32s you need a 3.5" lift
Red 1996 XJ Sport
4 Door, 4x4, 4.0 HO, Automatic Transmission
CD/MP3 Player - Sony Xplod 5.25" speakers
Rusty's 3" Full springs kit - 5" actual lift
JKS Quicker Disconnects
CB Radio + 4' Whip mag mount + Fully functional PA system
Yakima Load Warrior Safari Rack
30x9.5 kuhmo MT on 15x8 Soft8s with 4.75" backspacing
Rustys adjustable lowers.
helix is offline
post #3 of 12 Old 01-21-2005, 11:48 AM
kg6mti
1987 YJ Wrangler
Get the Ronco wheel shaver and adjuster kit.
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #4 of 12 Old 01-21-2005, 11:51 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
32" tires fit perfectly fine under a 2" suspension lift which gives more than enough vertical clearance. Your problem has nothing to do with the suspension lift height and everything to do with the excessive backspacing of your wheel that has the tire positioned too close to the suspension system. However, this is easily curable with a washer placed under both of the steering stop bolts per the instructions at http://www.imajeep.com/Steering_Stop...ering_stop.htm
Jerry Bransford is online now
post #5 of 12 Old 01-21-2005, 11:53 AM
Jerry Bransford
Administrator
Not true for a Wrangler TJ, and this is a TJ forum. A TJ can actually handle up to a 31" tire without a lift, with a 2" spacer lift providing more than enough clearance for 32" tires.
post #6 of 12 Old 01-21-2005, 01:36 PM
jonster
jonster's Avatar
2014 JK Wrangler
I, and a lot of others on this forum are proof that 32's and 2" BB will work. If you have stock wheels you will need either spacers or wheels with a different backspacing. I have not heard any rubbing even when wheeling or turning sharp. I have even gotten "air" at the top of some sand dunes and not had any problems.
2014 White JKUR
jonster is offline
post #7 of 12 Old 01-21-2005, 02:19 PM
KY TJ
KY TJ's Avatar
Like Jerry said, a couple of washers do the trick, and its cheap.
-Matt
99' 4banger 102" WB 36" IROKs
KY TJ is offline
post #8 of 12 Old 01-21-2005, 02:58 PM
sgrim80
What width? 10.5" or 11.5"?
sgrim80 is offline
post #9 of 12 Old 01-21-2005, 07:21 PM
Jerry Bransford
Administrator
Originally Posted by jenders
I've heard that 31's will rub when full locked? I'd like to for now put 31's on my TJ I've heard some people say they will rub when full turned and others say no what is true? Mine is stock for now but plan to lift later most likely a 2"BB. Thanks
Read my above post that gives a link to simple instructions on how to eliminate the minor rubbing that occasionally happens with 31x10.50 tires when the steering wheel is turned all the way.
post #10 of 12 Old 01-22-2005, 02:47 AM Thread Starter
Danlawson
thx for the link..... will fix it soon. good to know it isnt a complicated fix.
post #11 of 12 Old 01-22-2005, 08:35 AM
wayoflife
Click here to see my steering stop adjustment write-up
wayoflife is offline
post #12 of 12 Old 01-22-2005, 09:02 AM
Av Native
You can run a 31x10.5 on a stock tj with the stock rims, I was running that before i put any lift on my o4
Jerry is correct again as usuall, But there is a cheaper way to keep it from rubbing, "dont turn the wheel as far since you know they rub" It cost nothing and time involved to fix..
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline
tight turns on tarmac huttonj TJ Wrangler Technical Forum 8 01-23-2005 11:22 AM
*POP* going on in tight turns htownjeep TJ Wrangler Technical Forum 13 11-24-2004 08:45 AM
Chirping on tight turns? DutchmanAZ TJ Wrangler Technical Forum 14 11-24-2004 08:41 AM
when i make tight turns in 4x4 my jeep bounces forward! WHY??? jerrys yj YJ Wrangler Technical Forum 3 10-24-2001 01:45 PM
when i make tight turns in 4x4 my jeep bounces forward! WHY??? jerrys yj YJ Wrangler Technical Forum 3 10-23-2001 01:11 PM
