Wheeling tip for LSD - JeepForum.com
post #1 of 4 Old 09-02-2004, 03:38 AM Thread Starter
Baas
Baas's Avatar
Just a tip that you may know or maybe not.
If you get stuck try pulling up the hand brake to get the limited slip differential working.
It got me out of 3 pretty nasty bits this past weekend. Pity about the warning chime that beeps every time anyone got a fix?
Baas is offline
post #2 of 4 Old 09-02-2004, 08:12 AM
Jim Shanks
Jim Shanks's Avatar
Yeah, run an older TJ. My 98 doesn't ding at me... must be something they added in the newer ones.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #3 of 4 Old 09-02-2004, 08:26 AM
runmanpkll
just watch out for the rear brake backing plate when pulling that parking brake lever. the backing plates will bend in the rear if the parking brake lever is pulled to hard while giving it the gas. your probably better off just using the brake pedal to trick the LSD into thinking it has traction. the weak backing plate is probably why jeep put the chime in. my 02 has the chime also.
runmanpkll is offline
post #4 of 4 Old 09-02-2004, 12:47 PM
red99tj
red99tj's Avatar
must be nice not having open diffs like me
Frank
red99tj is offline
Going Wheeling!! mouse Wrangler General Discussion 11 02-13-2009 04:38 PM
new to wheeling! TheSherp TJ Wrangler Technical Forum 23 12-21-2008 11:27 AM
When you're wheeling... COMTB TJ Wrangler Technical Forum 26 03-13-2008 09:52 AM
so i went wheeling... pasadena TJ Wrangler Technical Forum 7 11-08-2006 07:26 PM
