Wheeling in ice - JeepForum.com
post #1 of 16 Old 01-17-2008, 10:12 PM Thread Starter
Bigsam
Wheeling in ice
Could wheeling in ice 2-2.5" thick put a hole in something. I have skids on most parts of the jeep just got it so not to sure what all is protected.
Bigsam is offline
post #2 of 16 Old 01-17-2008, 10:15 PM
YCP4x4
YCP4x4's Avatar
i unno about putting a hole in it, but if your on a lake i highly don't suggest it unless your SURE it's heavy enough ( let a friend go first!)... jk on the ().
2003 Rubicon ** SOLD **
4" Superlift
35" Mickey Thomson Baja Claws
YCP4x4 is offline
post #3 of 16 Old 01-17-2008, 10:22 PM Thread Starter
Bigsam
No I am just talking about like wheeling through pits Where the jeep breaks the ice up into chunks. I was wondering if one of the chunks could come up and put a hole in something
Bigsam is offline
post #4 of 16 Old 01-17-2008, 10:42 PM
djt283
djt283's Avatar
Depends how cold it is and how thick the ice is but I bet you could do some damage to something. I was playing in a sand pit a while back with my xterra and there was a little water under the ice. As my tires broke through, the ice on the sides of my tracks did a real number on my front rims and sidewalls. It looked like I's been driving next to a curb.
djt283 is offline
post #5 of 16 Old 01-17-2008, 10:47 PM
2005X
could do alot of damage, could break brake lines, bend rims, bend your tie rod, luckily fo me all it did was make my diff. fluid a milky grey color. pics below
2005X is offline
post #6 of 16 Old 01-17-2008, 11:00 PM
bman9089
bman9089's Avatar
you guys are brave. I'd hate to have to wade through water anyways if I got stuck. But through that stuff? Yikes!
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #7 of 16 Old 01-17-2008, 11:39 PM
fish4life
jeepcurious nice pics but you gotta check your breather hoses on the diffs. I've been in water that high plenty of times and never found milky diff fluid.... in fact i've had water in the tranny, but none in the diffs...
fish4life is offline
post #8 of 16 Old 01-18-2008, 07:41 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
can ice damage a jeep? well...Jeep is made of steel. The Titanic was made of steel. any questions?
they do ice wheeling/racing on the reservoirs up in the mountains. studded tires on tube buggies basically, but these res's are 6" thick, with no crevices.
Personally, I'm not going on water, whether it be solid or liquid, in anything that does not float.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 16 Old 01-18-2008, 08:06 AM
Heyduke
Watch your radiator. Ice can jam between that and your fan causing bad stuff to happen. Brake lines can be torn off. ARB lines also, if you have em.
The ice up to Georgetown is almost two feet thick. They park motorhomes on it. If you haven't raced on the ice. You are missing out on some real fun. Go up on a Sunday morning and get in line. It's like twenty bucks for a day of racing around on the ice. You don't need to run cheaters or studs to have fun. Dress warm though. It gets cold!
Heyduke is offline
post #10 of 16 Old 01-18-2008, 08:09 AM
COMTB
1989 XJ Cherokee
do you keep it in 4WHI or just 2W
the slipping on the ice would warrent the 4w but at the same token it might take some of the fun out of it. Just curious
COMTB is offline
post #11 of 16 Old 01-18-2008, 08:20 AM
Heyduke
If you want to win.....and we all do, you keep it 4. But you try real hard not to spin your tires. You gotta keep your speed at a controllable pace cause you're racing around a dogbone shaped course. It's all about control and not spinning off into the middle. It's really a blast. You try your lockers in the straights and unlock em in the corners. Street tires work better than muds do. Lot of people have a set of Hakapalettas mounted on rims just to race the bare rubber class. I never did. I just raced my mud TA's
Heyduke is offline
post #12 of 16 Old 01-18-2008, 08:58 AM
2005X
i only got water in the front diff. which is because of the Warn diff cover, the screws seem to come loose after wheeling for a but, and water seeped in
2005X is offline
post #13 of 16 Old 01-18-2008, 06:08 PM
Unlimited04
exactly, 2 feet thick is a lot different than 2" thick stated by the OP.
Useful Write-Ups:
Funny:
post #14 of 16 Old 01-18-2008, 06:28 PM
Jackle
that's takin a hell of a risk runnin through ice holes. unless you're absolutely sure.....you may not want to run over them because of depth issues....you might think it's only 6 inches deep but actuallity might have it around 3 ft. you should always check every water crossing before continuing on......yea i know its a huge pain in the ***.
Jackle is offline
post #15 of 16 Old 01-18-2008, 06:30 PM
tj120
watch your radiator the bottom is just plastic.
tj120 is offline
Going Wheeling!! mouse Wrangler General Discussion 11 02-13-2009 05:38 PM
When you're wheeling... COMTB TJ Wrangler Technical Forum 26 03-13-2008 10:52 AM
so i went wheeling... pasadena TJ Wrangler Technical Forum 7 11-08-2006 08:26 PM
Wheeling tip for LSD Baas TJ Wrangler Technical Forum 3 09-02-2004 01:47 PM
