Wheel spacers, Are they worth it? - JeepForum.com
post #1 of 18 Old 08-25-2010, 09:36 AM Thread Starter
LesterM
I found a deal on CL for 2" spacers for $100.
Are they worth the money?
I have 10.5 x31's that rub a little. Ive adjusted the steer stop.
I have old YJ rims for now.
Should I spend the money?
Where else should I spend my hundy if not?
I appreciate the feedback because I did not use the search feature.
2000 Wrangler.
LesterM is offline
post #2 of 18 Old 08-25-2010, 09:40 AM
sherminator866
you can get a brand new set of i think 1" for 60 bucks on rough country. i guess it depends on the brand and if you really need them. its not a bad deal though, pretty much right on for a used set from what ive seen.
sherminator866 is offline
post #3 of 18 Old 08-25-2010, 09:44 AM
RowJ
Only if they bolt on to the Jeeps tire lugs..... and have bolts attached to which you bolt the tire!
Loose spacers, IMO, are dangerous. If not familiar....read FAQ HERE
2" is alot of spacer for 31's.
RJ
RowJ is offline
post #4 of 18 Old 08-25-2010, 10:19 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
Offer them $60.I bought new RC wheel spacers for $120 (4).
TheBoogieman is offline
post #5 of 18 Old 08-25-2010, 10:24 AM
GIJOEBILL
No dont do it. I had a set and they chopped up my tires.
You can get some rims with backspacing and get the same effect.
Just my opinion.
Now-05 TJ & 96XJ
Then- 82 Wagoneer
90 MJ-98XJ
GIJOEBILL is offline
post #6 of 18 Old 08-25-2010, 10:25 AM
97yellow
you can buy cheap rims with the correct spacing off quadratrac for aroud 50 a piece
97yellow is offline
post #7 of 18 Old 08-25-2010, 10:29 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Pass on it.
2" is too much IMHO. 1.25" is the most you want. with 2" you'll need to press out the old lug studs and press new, longer ones in.
If you want a quality set = The Spidertrax Store
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 18 Old 08-25-2010, 11:15 AM
BYuen
BYuen's Avatar
I wanted to keep my aluminum stock wheels for the time being so I bought Spidertrax 1.25" wheel spacers. It was worth it. I didn't want the extra weight of steelies and the high probability I would bend the rims up on rocks and such. The spacers will get me through until I can afford some nice aftermarket alloy wheels or beadlocks
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #9 of 18 Old 08-25-2010, 11:32 AM
longbluerubi
I also have 1.25" Spidertrax, they've been working great. Needed them to compensate for larger/wider tires I put on. Definitely want to ensure they are installed properly and checked every so often. 2" seems wide for a spacer, puts a lot of extra pressure on things, 1.25" was the most I've heard that makes sense.
'05 LJ Unlimited Rubicon
I6 4.0L manual 6-speed
OME 2.5" lift+Nitrocharger Sport shocks
1" BL, JKS adj front & rear trackbars, JKS discos
33" BFG A/T
longbluerubi is offline
post #10 of 18 Old 08-25-2010, 11:43 AM
BYuen
BYuen's Avatar
A 2" wide spacer wouldn't put any more pressure on things than a wheel with equivalent backspacing.
2001 White TJ Sport
BYuen is online now
post #11 of 18 Old 08-25-2010, 12:18 PM
TheBoogieman
Jeepaholic
Exactly.
post #12 of 18 Old 08-25-2010, 02:47 PM Thread Starter
LesterM
Maybe they were 1", I should check the ad.
I've been on the road all day.
I do know that it is 4 for $100.
Deal or no deal?
2000 Wrangler.
LesterM is offline
post #13 of 18 Old 08-25-2010, 03:28 PM
Unlimited04
Deal or no deal?
1" will require trimming your front lug studs because they'll be too long.
like i said...1.25" is what you want.
Useful Write-Ups:
Funny:
post #14 of 18 Old 08-25-2010, 04:34 PM
Cdubu52
Im running 1.25" Spidertrax with JK Moab Wheels. Stick with the 1.25's. Love them so far. Be careful buying cheap spacers. Cheap spacers may not be properly balanced and could cause bad tire wear. Make sure to get a good spacer that you know is from a dependable company. Either get four spidertrax for $200 or get 4 new steel wheels with the correct backspacing for $200. Save up another hundred and youve got your choice between the two.
Cdubu52 is offline
post #15 of 18 Old 08-25-2010, 05:38 PM
gebirgziege
i have 1.25 inch, love it. i paid like 100 too. good deal.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
spacer , spidertrax , wheel spacer
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 09:27 AM
1.25 or 1.5 Wheel Spacers TimBrown TJ Wrangler Technical Forum 8 11-14-2008 04:11 PM
Jk Wheel Spacers JC KJ JK Wrangler Technical Forum 9 06-12-2008 06:17 AM
Are throttle body spacers worth it? MeGAMoE TJ Wrangler Technical Forum 14 10-03-2006 07:29 PM
Throttle body spacers....worth it?? FrankieBoy TJ Wrangler Technical Forum 1 05-02-2002 12:13 AM
