Wheel spacers = Death Wobble?? - JeepForum.com
post #1 of 23 Old 02-28-2010, 02:53 PM Thread Starter
hoovail
I just put a pair of used 37's on my 2001 TJ. Two are worn unevenly, and I decided to try and run them in the front. I wasn't surprised when I got DW at 35-40mph. So I switched the rears to the fronts, and took of the 1" wheel spacers all around. That fixed the DW, but now I'm wondering if the wheel spacers could have contributed to it?
Real Jeeps are built, not "bolt-on"!
hoovail is offline
post #2 of 23 Old 02-28-2010, 02:56 PM
Rubicon_Rob04
Your seat have a shake to it now at 35-40?
Rubicon_Rob04 is offline
post #3 of 23 Old 02-28-2010, 02:57 PM
Imped
Imped's Avatar
You didn't have DW. You had a little tire wobble.
OlllllllO
IndyORV
Imped is offline
post #4 of 23 Old 02-28-2010, 02:59 PM
mudb8
want it rite or rite now?
mudb8's Avatar
you have a stock Tie Rod dont ya?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #5 of 23 Old 02-28-2010, 02:59 PM Thread Starter
hoovail
I'm very familiar with DW. The DW is now fixed, and now I have the normal TJ tire wobble!
hoovail is offline
post #6 of 23 Old 02-28-2010, 03:00 PM
ValleyJeeper
Worn wheel spacers are not good. If they move at all, they will unbalance the wheel and driving will be bad. You will definitely feel it up front. Its still happening in the rear, you just don't feel it.
I had a set with stock rims that I had to re-torque every 2 weeks. They went in the trash when I bought new wheels.
ValleyJeeper is offline
post #7 of 23 Old 02-28-2010, 03:00 PM
durango-bob
2006 WK
There are many things that can cause DW and tire balance is a big one. Spacers by themselves shouldn't cause the problem but can make it worse since the tires are further out and any balance issue now gets more leverage.
durango-bob is offline
post #8 of 23 Old 02-28-2010, 03:01 PM
Vandano
you would be surprised if you got death wobble.
Your where experiencing a shake due to an unbalanced tire. I believe the shaking was resolved more from moving the uneven tires to back not from removing the spacers.
Death wobble is the violent uncontrollable shaking that is only resolved by coming to a complete stop and wont be caused by an unbalanced tire.
Originally Posted by never monday View Post
when life gives you lemons.....make a trail rig out of it.
Vandano is offline
post #9 of 23 Old 02-28-2010, 03:04 PM Thread Starter
hoovail
Tera High Steer, Rubicon Express track bar with 8,000 miles on it. Track bar bracket welded to the top of the axle. The track bar and drag link are almost perfectly parallel
hoovail is offline
post #10 of 23 Old 02-28-2010, 03:05 PM
Vandano
are they properly torqued with no movement? have you had some turn the steering wheel lock to lock and see if anything moves that shouldnt
The tire balance may "initiate" the death wobble but is not the cause. Something is loose or worn and its not your stabilizer.
Vandano is offline
post #11 of 23 Old 02-28-2010, 03:06 PM Thread Starter
hoovail
I never heard that before, but after removing them, I thought maybe that could have been the case. Thanks
hoovail is offline
post #12 of 23 Old 02-28-2010, 03:07 PM
mudb8
mudb8's Avatar
How much does the RE track bar flex in the bend when someone is turning the wheel back and forth?
mudb8 is offline
post #13 of 23 Old 02-28-2010, 03:19 PM Thread Starter
hoovail
When I installed the HS and TB everything was dialed in. I will be checking all torque specs, and everything else related to DW if it returns, for now it is back to normal. Everything was fine with the 35's. It started happening with unevenly worn 37's. I suspect my caster is not correct which may be the real cause.
Side note: these are balanced with BB's. About 12oz in each tire.
As far as I can tell, the spacers were not worn. What exactly wears on a spacer?
hoovail is offline
post #14 of 23 Old 02-28-2010, 03:32 PM
Imped
Imped's Avatar
The BB's may be doing it. As novel as the idea is, I've not been able to make it work. After going to standard weights and road force balancing, my tires are smooth. They were not smooth above 50ish with BB's.
OlllllllO
IndyORV
Imped is offline
post #15 of 23 Old 02-28-2010, 03:43 PM Thread Starter
hoovail
This is the second time I tried BB's. The first was when I was trying to diagnose DW the first time. I got rid of them thinking they were the cause, but that did not fix the DW. I have always been skeptical of BB's, but love the idea of not paying for a balance, and not having them go out of balance over time. Smooth tires over 50ish sounds great though!
hoovail is offline
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
Death Wobble cured, but wheel still shaking pretty bad dyenom TJ Wrangler Technical Forum 1 07-13-2009 07:15 AM
Death Wobble after 1.5" wheel spacer install BWFBezerk TJ Wrangler Technical Forum 19 02-18-2009 06:23 PM
Just replaced wheel bearing...STILL death wobble! Brandon97TJ TJ Wrangler Technical Forum 14 11-29-2008 06:18 AM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
