Wheel Spacers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Wheel Spacers
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 10-03-2007, 09:29 PM   #1
scanderw
Wheel Spacers
Interested in your views/experiences with wheel spacers.
scanderw is offline   Reply With Quote
Unread 10-03-2007, 09:41 PM   #2
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
New wheels are less expensive. I bought all 5 of my rims for $200 shipped. You can only buy 4 spacers for that much.
If you want to keep your stock wheels, there is ABSOLUTELY NOTHING wrong with wheel spacers. If anyone else tells you other wise, they're talking out of their ***. They are perfectly safe as long as the instructions are followed during installation.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote
Unread 10-03-2007, 09:50 PM   #3
scanderw
Well I already have the spacers.. have a serious vibration goin on at certain times on the road not sure if that could be caused by the spacers or not. Can you recommend any good tire and wheel websites?
Unread 10-03-2007, 09:50 PM   #4
Rocky529
Jeep
Rocky529's Avatar
I run them and have no problems with them. They are safe. Torque them to 100 ft/lbs and re-torque them after 50 miles and you'll be ok.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 10-03-2007, 09:54 PM   #5
scanderw
alright i'll give it a try thanks.
Unread 10-04-2007, 06:24 AM   #6
erickpl
Also make sure your tires/wheels are properly balanced. Some tires are harder to balance (like TrXuS MT's). Bigger tires especially.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
