Wheel spacers - JeepForum.com
post #1 of 10 Old 10-18-2010, 08:52 AM Thread Starter
redmater06
Wheel spacers
Just a quick question, if im using factory jeep wheels with a 33x10.5xR15 tire with a 4 inch suspension lift do i need wheel spacers? or dio i only need spacers for a 12.5 tire? Thanks
redmater06 is offline
post #2 of 10 Old 10-18-2010, 09:29 AM
BYuen
BYuen's Avatar
Assuming your factory wheels have 5.5" of backspacing and the majority (not all) of them do, then no you won't need spacers. With 10.5" wide tires you should be fine. You might rub a little in a few places. Generally speaking, you need 4.5" backspacing or less to run a 12.50" wide tire.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 10 Old 10-18-2010, 11:29 AM
otisdog
2008 WK
Double check the clearance between your tires and the upper rear spring perchs.
I'm running 33 x 10.50's and on stock Gambler wheels with 5.25" backspacing. There was not enough space for my liking so I added spacers.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #4 of 10 Old 10-18-2010, 12:35 PM
TheBoogieman
Disturbed Rubicon owner
TheBoogieman's Avatar
They will clear but wheel spacers give it a better stance and clearance.
TheBoogieman is offline
post #5 of 10 Old 10-18-2010, 01:56 PM Thread Starter
redmater06
thanks guys...yeah ill be using the gambler wheels and i believe if i read the tape measure rite they have about 5.5 inches of backspacing. Appreciate it.
post #6 of 10 Old 10-18-2010, 02:16 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
will you be centering the axles with adjustable track bars?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 10 Old 10-18-2010, 08:11 PM Thread Starter
redmater06
Thats news to me, please educate me on centering the axles and what that has to do with wheel spacers. Thanks bud
post #8 of 10 Old 10-19-2010, 01:31 AM
BYuen
BYuen's Avatar
Unlimited04 is referring to your 4" suspension lift not wheel spacers. If you don't have a track bar drop bracket or an adjustable track bar, lifting your Jeep only using the stock track bars will shift the axles more to one side or the other depending on how high the lift is. Thus, affecting your tire clearance. The front axle will shift more to the driver's side and the rear axle will shift more to the passenger side as you increase suspension lift without doing anything with the track bars. So when worrying about tire clearance, also take into account whether or not your axles will be centered.
2001 White TJ Sport
BYuen is offline
post #9 of 10 Old 10-19-2010, 11:25 AM Thread Starter
redmater06
the rear will have a drop bracket, and front will have an adjustable track bar, so i assume i should be fine and axles will be centered
post #10 of 10 Old 10-19-2010, 11:32 AM
TheBoogieman
Yup and don't listen to Unlimited04,he's still pissed about his auto tranny and the mountains he lives in.The goats are showing him up on the steep terrain. (JK)
10.50" , 12.50" , backspacing , clearance , tire , wide
Wheel Spacers SoCalJK JK Wrangler Technical Forum 21 09-17-2010 05:45 PM
Will I need wheel spacers? jjohnston05 TJ Wrangler Technical Forum 2 05-31-2010 04:04 PM
Do I need wheel spacers bking TJ Wrangler Technical Forum 6 11-13-2009 11:29 AM
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
wheel spacers tdoshi9 YJ Wrangler Technical Forum 2 05-23-2007 02:11 PM
