wheel backspacing ignorance...can someone explain it to me like I am 5 years old?? - JeepForum.com
post #1 of 20 Old 02-05-2010, 05:07 AM Thread Starter
Nute4Christ
I want to keep my stock canyon rims...but I see on here that the backspacing is not enough.....I know about wheel spacers. but how is backspacing measured and how much will i need to run stock canyons with 33x12.50's? please share.
Nute4Christ is offline
post #2 of 20 Old 02-05-2010, 05:21 AM
99TJSahara
less backspacing=wheels stick out further
more backspacing=wheels tuck in
Your canyons have 5.5 backspacing, spidertrax(1.25'') spacers will put your backspacing at 4.25, you will be fine with canyons and spacers
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #3 of 20 Old 02-05-2010, 05:39 AM
robncar
robncar's Avatar
Agree with 99TJSahara, well said and succinctly put...
Backspace is the measurement taken from the backside wheel edge to the mounting surface as in the picture below. This wheel would have a backspace of about 3.75 if I'm reading the tape correctly.
mufp_0612_02z+ford_mustang+wheel_backspace.jpe
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 20 Old 02-05-2010, 07:48 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Get your widdle itty bitty wheel spacers that are 1.5" thick and put your big ol knobby tires on your factory wheels.
TheBoogieman is offline
post #5 of 20 Old 02-05-2010, 08:19 AM
mschviuz
modified a bit
Even better.....
Get your widdle(spongebob squarepants) itty bitty wheel spacers that are 1.5" thick and put your big ol knobby(dora the explorer) tires on your factory wheels.
Rotflmao!
mschviuz is offline
post #6 of 20 Old 02-05-2010, 08:38 AM Thread Starter
Nute4Christ
ha ha ha! I deserve that!
post #7 of 20 Old 02-05-2010, 08:50 AM
champelite210
One guy says 1.25 the other says 1.5. Which one is it that doesn't rub?
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #8 of 20 Old 02-05-2010, 09:14 AM
TheBoogieman
Either will work.I have the RC 1.5" wheel spacers on mine and no rubbing at all.
post #9 of 20 Old 02-05-2010, 09:31 AM
hawk3ye
I'm using 1.25" spacers with the exact setup you mentined...if u have any sort of lift, double check to make sure there's no tire rubbing the rear drivers side coil spring perch...it's a disc looking thing where the big coil spring kinda gets held in
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams
hawk3ye is offline
post #10 of 20 Old 02-05-2010, 10:18 AM
BYuen
BYuen's Avatar
Granted you have an adequate amount of lift, Spidertrax 1.25" spacers will give you plenty of backspacing to clear a 33x12.50 wide tire. Canyon wheels have 5.5" of backspacing, so with the 1.25" spacers you'll have a net backspacing of 4.25". The maximum amount of backspacing you can get away with without extreme rub with a 12.50 wide tire is 4.5" of backspacing. I still have my Canyons and I'm running a 35x12.50 tire. No rub issues. All I had to do was add two washers to my steering stops to keep the rubber out of the LCAs.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #11 of 20 Old 02-05-2010, 05:37 PM
BlueFlame
BlueFlame's Avatar
Here, this is fun to play with.
Wheel / tire size calculator / comparer - BIGCUSTOMWHEELS
BlueFlame is offline
post #12 of 20 Old 02-08-2010, 11:54 AM
SpaComponents
what about lift?
I'm trying to do exactly the same fit 33-12.50/15 on Canyons, and am ignorant as h... about this, but don't we have to consider lift and whether or not adjustable track bars or brackets got installed?
I have 2" lift and axles are now offset maybe 1/2" left and right of stock positions
SpaComponents is offline
post #13 of 20 Old 02-08-2010, 12:58 PM
hawk3ye
If I translated your comments correctly, you have a 2" lift and you have a 1/2 axle shift and you want to go with 33x12.5 tires?
You need a 1.25" or 1.5" spacer for sure. After tire installation, even with the spacers, double check whether your coil spring perch on the driver rear side is rubbing your tire or not, this is important as you may damage your tire's inner side wall. Sorry I don't have pix show this but there's plenty here on the forum to show what I'm talking about, look up "coil spring perch rub" or something to that effect.
hawk3ye is offline
post #14 of 20 Old 09-26-2010, 09:08 PM
94ZJ-318
Alright so a wheel with 4.5 back spacing will be tucked in CLOSER to my Jeep than a wheel with 3.75? Why is something so simple so F...ING confusing? It just doesnt make sens to me? The way I see it..okay if the mounting surface is deeper into the rim, I would believe that it would stick out farther? Idk man this sucks I just want my wheels not to rub on my CAs when I turn!!!
94ZJ-318 is offline
post #15 of 20 Old 09-26-2010, 09:11 PM
biffgnar
biffgnar's Avatar
I think you need to think about it a little more. Mounting face deeper in the wheel means less wheel outside the mounting face and thus wheel sticking out less.
biffgnar is offline
Backspacing for Dummies.....Please Explain Grizz64 YJ Wrangler Technical Forum 14 07-03-2013 11:59 AM
explain backspacing please (pics) xtremescootr YJ Wrangler Technical Forum 7 11-02-2009 03:21 PM
Confused about backspacing and overall wheel size (What backspacing for a TJ?) uknowwho TJ Wrangler Technical Forum 21 10-03-2009 10:12 AM
Part Three of the "explain this to me like I'm 8 years old..." (Tires) matt3liv TJ Wrangler Technical Forum 12 05-22-2006 02:29 PM
Part Two of "explain this to me like I'm 8 years old..." matt3liv TJ Wrangler Technical Forum 19 05-19-2006 01:05 PM
