#1 | |
Wheel Backspacing
I have a 2004 Rubicon with a 2" Rubicon Express budget boost and a 2" body lift. Im running 305/70/16 Dunlop Mud Rovers with stock Moab rubicon wheels. I was looking for some Cragar Soft 8's or either the Pro Comp 97's. How much of a backspace do I need?
#2 |
Seeing as that tire is around 12 inches wide I would run 3.75 or 4 inch backspacing.
05 RUBI |
#3 |
Thats what I run on rockcrawler 152's
05 RUBI |
#4 |
JEEP FREAK
Welcome to the forum.
![]() Here is some good info from the FAQ on what backspacing you need: Width The tire width you can use on your TJ is determined by the backspacing of the wheel. Stock TJ wheels have backspacing ranging from 5"-5.5". A list of stock TJ wheel specifications including backspacing can be found HERE The chart below is intended to be used as a guide only. Different tire brands will vary in actual width. You may have slight rubbing when turning full lock if you are running the MAXIMUM suggestion below. ![]()
98 TJ |
#5 |
15x8 4" backspace $40 each at summit
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRR-3975812&N=700+115&autoview=sku
2001 TJ 4.6 Auto 4.5" AEV suspension 35's 2002 TJ 4.0 Manual 3" BDS suspension 33's 1987 Chevy 1 Ton 12" suspension 44's 1970 Cutlass 442 468CID TH400 1999 7.3 Powerstroke |
#6 |
"4BS on my cragers with a 12.5 wide tire
www.youtube.com/kgries http://photobucket.com/kgries in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash.. |
#7 |
Demonic Jeep Freak!
It depends also how far do you want them to stick out past your flares.Some states actually have laws.![]() |
#8 |
Purveyor of Funk
OK, I know this is a total noob question, but I just bought my first Jeep and am wondering how the backspacing affects how far out a particular tire sticks out of your fender flares / tire wells. Does it actually affect where the tire rides on the wheel itself, placing it closer or farther from the axle/hub? Or what?
#9 |
Less backspacing=wheel/tire sticks out further. Backspacing is a measurement from the mounting surface of the wheel to the back lip of the wheel. It does not affect where the tire rides on the wheel.
05 RUBI |
#10 |
Purveyor of Funk
Ah, very nice. I've always preferred the Jeeps' look when the tires stick out a little further. I'm planning on 33x10.5R15 BFG M/T KM2's on Mickey Thompson Classic II's (15x8), which have a backspacing of 3 5/16", which apparently means it can easily take 12.5's should I decide to move to those, and apparently it'll stick out nicely, too
![]() Thanks! |
#11 |
use the information here- http://www.jeepforum.com/forum/showthread.php?t=452871 to fill out the information here- http://www.wheelsmaster.com/rt_specs.jsp
It will tell you everything you want to know from change in mph to clearance dimensions. It is intended for use on cars which it does a great job at, i dont see why it can not be used for a jeep too. hope you find it useful. |
#12 |
Trust me if you want things to stick out the 33X12.5s on the Mickey Classic IIs will stick out. I just put on he MTZs on those wheels & they throw mud all over the Jeep. Just ordered the Bushwacker 6" Flat Flares to help ( they will still slightly stick ou) remedy this.
2004 LJ- 33X12.5 Mickey MTZs, Mickey Classic II wheels, 4.88 Yukon Gears, 3" BDS SL, Rockhard Rear Bumper with Tire Carrier & Rockers. Oil Pan, Warn Gas Tank Skid. & Differentials armoured, Iggee Seat Covers, Warn M8000 winch.AEV TT & tranny skid, radiator & steering box skids |
#13 |
i plan on doing the same setup (33x12.5x15) on cragar soft 8's with 4" BS.. i'm just hoping it doesn't stick out too far past my stock fender flares.. but we shall see.
'05 Wrangler Unlimited, BDS 3", 33's, Blah blah '00 Cherokee Sport... Stock. 80,000 miles and counting on the booty 0331 head |
#14 |
I running 4.5BS on my rubi with 305/70/16 and I think it is perfect.
Here's what it looks like: ![]() ![]() ![]()
-Steve- 2004 TJ Rubicon OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs - Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid - Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid - Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper RIP: 2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD. 2 motors, 2 trannies, 150k miles before I parked it. Jeeps Going Wild Last edited by Strizzy; 04-30-2009 at 02:05 AM.. |
#15 |
05LjNj:
My current setup up has the tires out almost 3" from the flares. The Clasics are 3 5/16th bs which is 2 1/4" more than the stock ravines, & the tires 12.5 so 3" wider than stock 30X9.5 that came with the LJ so overall 1 1/2 imches plus 2 1/4 inches so the probably are 3 3/4 inches outside the flares, noticeable but not horrible looking but the mud definitely gets thrown over the Jeep. New Flat Flares I have ordered will give about 3" more coverage than stock so it will hel rectify this issue (but not perfectly). 4" bs would have been better.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
