wheel about to touch spring on back - JeepForum.com
post #1 of 7 Old 08-06-2010, 12:07 PM Thread Starter
Brak54
hey guys i was just doing a oil change and like always i just out under the whole jeep to see if anything is lookin messed up or what not.
anyways i was looking and the back driver side tire is like 1/4in from touching part of the spring and the back pass side is like 2-3 inches away what does this mean? i will have pics up in about 5 min
i took a good like at the tire and it never touched it yet so thats good
if this helps i have 33's 10.5 and a 4.5in lift
this is the close one
this is the other side
Brak54 is offline
post #2 of 7 Old 08-06-2010, 12:11 PM
csabo98
I had a similar problem. When i did my lift i had to put a rear adjustable track bar in even with the relocation bracket. That will re-center your axle with the proper lenth. I also went to new rims so with a different offset later to accomidate 12.5" tires.
csabo98 is offline
post #3 of 7 Old 08-06-2010, 12:22 PM
RubiconRazorbac
RubiconRazorbac's Avatar
As csabo said, you need to center your rear axle. Hopefully that 4.5" lift came with an adjustable rear trackbar. If not, time to get one
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #4 of 7 Old 08-06-2010, 12:27 PM Thread Starter
Brak54
aww man lol how hard is that to do?
Brak54 is offline
post #5 of 7 Old 08-06-2010, 12:27 PM Thread Starter
Brak54
jeeps are never ending i guess ill start lookin for one now
Brak54 is offline
post #6 of 7 Old 08-06-2010, 12:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's not hard. You can take the less expensive route by simply installing a rear trackbar relocation bracket. The bracket will move the axle back in the opposite direction to what your suspension lift did to it. Like this one RE1603 - TRACK BAR BRACKET TJ REAR W/O - Rubicon Express. Or go with an adjustable length track bar which is a better fix but the relocation bracket will work fine too.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #7 of 7 Old 08-06-2010, 12:43 PM Thread Starter
Brak54
Thanks!! You're the man.
Brak54 is offline
axle , center , centering , rear , tj , wrangler
PROBLEM: Vehicle/steering wheel/back right wheel shake badly. Black99ac TJ Wrangler Technical Forum 5 10-11-2007 12:41 PM
How to get the spring back in the mirror? jeeptrix TJ Wrangler Technical Forum 3 07-18-2007 10:36 AM
RE spring touch-up? Polaris TJ Wrangler Technical Forum 10 09-06-2006 07:29 PM
moab wheel touch up paint.... artboy TJ Wrangler Technical Forum 10 06-19-2006 08:46 PM
Back to a Spring Under koopzz YJ Wrangler Technical Forum 1 06-14-2004 06:30 PM
