whats wrong with my jeep need answer asap (Jeep won't idle after jump start) - Page 2 - JeepForum.com
post #16 of 25 Old 11-03-2008, 09:21 AM
gaucho919
mrblaine is right, that's a common misconception that I thought was true when I bought my wrangler in 05. I used to drive a 91 s10 with a 4.3 and I could bump start it without a battery at all. not so on my wrangler, I have tried it before when the battery died, a buddy yanked me around with an old volvo, with no results, and the only way it started was with jumper cables
"The journey is the destination"
gaucho919 is offline
post #17 of 25 Old 11-03-2008, 09:27 AM
Wif
Wif's Avatar
Originally Posted by Skyryder View Post
.. it has to be excited to work(really)
Don't we all
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #18 of 25 Old 11-03-2008, 09:32 AM
DaOne
DaOne's Avatar
Nope, very common misconception. The alternator, as has been stated, needs voltage from the battery to produce current needed to run the rig.
That's another reason why all the manual trans owners are wrong when they state one of the reasons to own a manual is so you can bumpstart if your battery dies. If the battery is dead, you can drag it around the block with another vehicle and it won't run until there's enough juice in the battery to keep it going.
I knew I heard this before and I wasn't crazy
Glad you got it to stay running.
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline
post #19 of 25 Old 11-03-2008, 09:43 AM
robertdeal
i got a pic on my profile but i want it under my name when i reply to posts
robertdeal is offline
post #20 of 25 Old 11-03-2008, 09:07 PM Thread Starter
Wrangler11
Wrangler11's Avatar
that's all it took, a good charge. I actually traded in today of a new 08 grand cherokee I'm actually pretty depressed and miss it.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #21 of 25 Old 11-04-2008, 12:03 PM
Sccafire
I know you don't have the Jeep anymore but this it what happened.
Its kinda hard to explain but what happens is the computers loose it memory. After the Jeep is restarted it needs to go thru a relearn process.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #22 of 25 Old 11-04-2008, 02:24 PM Thread Starter
Wrangler11
Wrangler11's Avatar
^ interesting
post #23 of 25 Old 11-04-2008, 02:28 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
What many don't realize about the type of alternator the TJ uses is that it won't put out any power out whatsoever with a dead battery. The TJ's alternator absolutely requires a 12 volt "exciter voltage" from the battery or it won't/can't put any (!) power out. And if the battery is weak, the alternator won't put out enough power so the engine will run well.
So if the battery was so weak that it needed a jump start, the engine will not run once the jump-start battery is disconnected. Fully charge your battery or replace the battery if a load test indicates it is bad and your engine will run fine again.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #24 of 25 Old 11-04-2008, 03:39 PM
tj99
tj99's Avatar
My son's ran his battery down twice now, no doors so no headlight chime.
We've had to let the battery charge a bit from the charging source and then it would start but not idle.
Driving it for a few miles while pumping the gas will let the battery charge enough so it runs correctly.
1998 2.5L 5Spd - Sold
1999 4.0L Auto - Mine
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
post #25 of 25 Old 11-04-2008, 04:46 PM
Sccafire
That is all part of th relearn process
Scott
Sccafire is offline
whats wrong with my jeep? cr125racer YJ Wrangler Technical Forum 12 01-03-2013 12:19 AM
Jeep wont idle at all?? whats wrong? sheebaracer YJ Wrangler Technical Forum 2 05-12-2009 01:51 AM
whats wrong with my jeep SWAMPED YJ Wrangler Technical Forum 4 08-31-2007 03:26 PM
jeep want idle after jump start emt8c TJ Wrangler Technical Forum 4 06-14-2007 02:35 PM
NOW whats wrong with my Jeep!!! Parabola YJ Wrangler Technical Forum 5 04-03-2004 08:53 AM
